586,393 active members*
2,974 visitors online*
    Jul 2014
    setting start location.
    Hey all.
    I have the ebay k40 using moshidraw 2014.
    I am trying to figure out how to set the start position. In the output cut window I can position the laser anywhere I want over the cutting bed and that works fine. When I press output the laser moves to the top left corner hits the home switches then moves about 1.5 inches to the right and begins the cut/engrave process almost over the vent tube. I cant find any settings to tell the machine where to begin. I am new to laser engraving and the moshidraw software so I must just be missing something right?
    Here is a video of a square I have made in moshidraw 2014 and the laser engraving (laser off) in the wrong place.
    Hopefully someone can point me in the right direction.
    Thank you.
    Jul 2013
    did you happen to get this figured out? i am having the same issue.
  1. Setting Home Location, Table Travel, and Home Switch Location in Stepconf
    By northbear in forum LinuxCNC (formerly EMC2)
    Last Post: 08-25-2013, 05:07 AM
  2. Replies: 0
    Last Post: 03-19-2013, 05:17 PM
  3. Scriber Drill M08 Location before X Y location
    By bearings in forum SheetCam
    Last Post: 01-18-2013, 11:04 PM
  4. Setting Start Point
    By Hellbringer in forum Mastercam
    Last Post: 11-24-2008, 05:29 PM
  5. Mach 3 Wizards Z Start Setting
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2008, 11:35 PM
