586,655 active members*
2,571 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > Can the Mach3 Write Wizard be programmed to cut the same pattern more than once
    Jul 2014
    5
    Question Can the Mach3 Write Wizard be programmed to cut the same pattern more than once
    Is there a way to set the Mach3 Write wizard to repeat the same pattern more than once in case you want to cut deeper than one cut will normally allow
    Re: Can the Mach3 Write Wizard be programmed to cut the same pattern more than once
    Set the depth to the deepest cut you want, and then save the g-code.
    Then, use the multi pass wizard on the g-code to create multiple passes.
    Jul 2014
    5
    ger21;
    Thanks for the quick reply. More questions. Never having used multipass wizard before, can you give me some advise on using it. I guess I should save on exit when through with the write wizard then return to Mach3 and activate the Multipass wizard.I suspect I should set the Rapid height, the depth, the feedrate all to the same as originally set in the write wizard. Then the step depth should be set to the amount of desired for each step. What do I do with x shift, y shift and feedrate plunge. Finally click on convert code/exit. Am I correct
    Yes. After the write wizard, go to the multipass. X and Y Shift should be 0. Plunge can be whatever feedrate you want to plunge at.
  1. Mach3 write wizard changes depth of cut during cutting
    By pasofinojls in forum Mach Wizards, Macros, & Addons
    Last Post: 07-12-2014, 08:40 PM
  2. Mach3 Write wizard bug?
    By rnr107 in forum Uncategorised MetalWorking Machines
    Last Post: 03-12-2011, 11:55 AM
  3. Mach 3 write wizard
    By Jig Maker in forum Engraving Machines
    Last Post: 03-02-2011, 07:14 PM
  4. Write Wizard Help!
    By ibuildstuff4u in forum Mach Wizards, Macros, & Addons
    Last Post: 08-12-2009, 06:25 AM
  5. Write wizard...To many numbers
    By Scott_M in forum Mach Wizards, Macros, & Addons
    Last Post: 02-09-2007, 07:14 PM
