587,008 active members*
3,259 visitors online*
Results 1 to 8 of 8
    Jul 2003
    151
    Concidering micro stepping?
    Here is a very good read for anyone thinking about micro stepping.
    http://lists.newsforindustry.com/cgi...Kr0CKf0BEHx0Af
    Chart at the bottom of the page says a lot...
    Oct 2003
    92
    Thanks for the link! That article is talking purely about micro stepping. But what if you combined micro stepping with a chopper controller? I guess the first question is; can a chopper controller do micro stepping? If so, how would the numbers in the chart change (if at all)?
    --bb99
    There are 10 types of people in this world; those that understand binary and those that don't.
    Jun 2003
    3312
    choppers vs microstepping. The Allegro 3977 does both. Just thinking off the top of my head, I'm not sure you could do microstepping without chopping.
    Jan 2004
    71
    Definitely go the microstepper route, lower motor resonance and smoother performance.
    Try this, 3amps and up to 55volts. The nice thing is it is a microstepping chopper driver board. Software is online and the design works great. Very smooth at 8 microsteps.
    http://www.embeddedtronics.com/microstep.html
    Kin Fong
    Robotics, CNC, and Controllers
    Jul 2003
    200
    Microstepping requires that the current level in the stepper coils be controllable.
    Chopping is the most common way these days to control current in a stepper motor coil.
    There are other ways to control the current in a stepper coil.
    Therefore the answer is that you CAN do microstepping without chopping. The linistepper is an example of one approach.
    But choppers are more common and more efficient...
    Hope this helps,
    Ballendo
    "Chopping" is a particularly noxious way simple switching drives use to regulate motor currents. They are characterized by hissing, squealing and grunting sounds from the motor that result from two free-running oscillators that interact by alternatingly phase-locking and breaking phase lock (it's what makes all the unpleasant noise).
    This is the method used by all the common L297/298 and Allegro circuits floating around the web.
    Generally, don't trust circuits developed by integrated circuit manufactures. This is anti-intuitive I realize. You would think an IC manufacturer would have the best application notes and a circuit to match. Fact is, they are IC circuit mfgs, not motor drive design engineers. If you have any doubts, why does their stuff hiss and squeal?
    The reason is most motor drive ICs are considered a backwater by IC mfgs and they assign the greenest engineeers to those products. They mean well but their designs are naive.
    That is the reason I eschew the ready-made solutions and I "roll my own". A proper motor drive should be synchronous, i.e. a clocked PWM (pulse width modulated) design. It should be silent while stopped or turning at low or moderate speeds, it should not squealing like stuck pig.
    The other drawbacks of packaged IC designs are too numerous to deliniate: no 2nd order damping, no reversion to full-step reference at higher speeds, etc, etc.
    Mariss
    Feb 2004
    15
    Sounds very interesting, are you using a PIC to navigate the idiosincrocies "eschewed"?????
    Nope. 4000 Series CMOS.
    Mariss
  1. harbor freight micro mill
    By gearcut in forum Benchtop Machines
    Last Post: 02-18-2010, 09:24 PM
  2. eas micro stepper
    By natchez in forum Stepper Motors / Drives
    Last Post: 05-14-2005, 06:01 AM
  3. help with micro stepping
    By chrisw765 in forum Xylotex
    Last Post: 03-05-2005, 01:26 PM
  4. Need help Japan Servo Stepping motor ?P-86sv2-003 data?
    By jlagran he in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 09:36 AM
  5. New to Mill and CNC - Can you mix a Mini and Micro Mill
    By Sherpa in forum Benchtop Machines
    Last Post: 09-09-2004, 03:36 PM
