586,094 active members*
3,926 visitors online*
    Aug 2011
    617
    Chinese 50w laser, stopped firing
    Hi all
    I've had a chinese 50w laser machine for a couple of months now.
    Didn't use it much for the 1st month .. siting it, figuring the software etc..
    Started using it and probably about 15hrs cutting so far.
    Last week towards the end of a cut, the laser output stopped.
    How can I find out if it's the tube or psu ?
    Water protect light is working
    there are no interlock cutouts on this machine
    Test button on PSU does nothing
    PSU fan works and power on led functions
    I've done a test requested by the supplier where I take the psu output wires and wrap then round a dowel approx 3cm apart and hit the test button ... nothing .. they are expecting an arc
    They asked me to open the PSU and photo and look for any burned components .. all looks clean
    I've googled lots and can't find any way to determine if the PSU is ok without a working tube.
    some suggest a resistor .. others say this is way dangerous !
    Help please, before I have to buy a tube and psu to find out which is broke !
    Richard
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Jul 2014
    19
    Nov 2014
    Re: Chinese 50w laser, stopped firing
    Hello. I was wondering if you ever found a solution to this problem? My machine did the exact same thing and I'm having a hard time figuring out what part is bad?
    Glenn
    Dear, Sir
    I have read your question.
    Generally speaking,the laser machine does not working without laser,maybe there are some reason as followed:
    1.The laser tube is damage.
    2.The laser power supply in damage.
    You also can try short connect.If do this,the laser tube have laser,the reason will be damage of water sensor.
    I'm Ula,any question you can contact me by Skype:sukelaser9
  1. Universal Laser does not stop firing even after the job stops?
    By wickedboysap in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2014, 02:28 AM
  2. Laser not firing
    By BuckeyenNJ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2012, 10:57 PM
  3. Optional Acessories Introduction of GWEIKE LASER / CHINESE LASER
    By Melody-gweike in forum News Announcements
    Last Post: 04-14-2012, 02:37 PM
  4. firing laser in Mach3
    By pjeffers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-25-2011, 10:59 PM
  5. Laser stopped firing - HX40B
    By shazz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-13-2010, 09:15 AM
