586,536 active members*
2,797 visitors online*
    Hello
    I am new here and hope you are able to help me out.
    I have the following problem:
    I have created a contour in Shopmill that I would like to mill now
    My raw part is so big, that my cutter would leave some residual material.
    That’s why I thought about the soft key “mill contour” > "mill studs", so that I can chip plane Z immediately to the final depth and in plane XY about 5 mm.
    So far it was clear to me.
    However in the simulation it looks like I mill a pocket.
    Can anybody help me out?
    Thank you
    hapo Guest
    Hello
    When milling contour studs, you need two contours.
    The first contour describes a raw part and the pre-processed contour. The second contour describes the contour that is to be processed. When both contours are defined, both are combined in the editor with a bracket afterwards, only then the simulaton works properly.
    With the cycle contour studs you are NOT able to mill a pocket. Unless you pressed the wrong soft key by accident.
    Hello Hapo
    Exactly that was my mistake.
    I thought that the raw part description at the beginning is enough for the simulation!
    I knew I cannot mill a pocket with the soft key. It only looks like this in the simulation
    Thank you for the help
