586,523 active members*
3,514 visitors online*
    428
    Hi
    I once wanted to inquire whether you have this problem too.
    With our DMG machines with MillPlus controller we want to load programs from the network to the machines but the message that we have too many files always comes up.... there are about 200 programs in the particular machine folder.
    Does anyone of you have a solution so that the controller can handle more than 200 programs? Or is this a "protection" so that the controller is not overloaded when processing the directory?
    <!--coloro:#000000--><span style="color:#000000"><!--/coloro--><!--fonto:Franklin Gothic Medium--><span style="font-family:Franklin Gothic Medium"><!--/fonto--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->Mit schönen Grüßen aus dem Badnerland<br />Stefan<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--><!--colorc--></span><!--/colorc-->
    Oct 2005
    241
    Hello Hunterkoile
    The maximum number of files is determined by a machine constant. I would not advice you to change that constant because then all the tables (zero points, tools, etc.) will be deleted as well as the position of the axes that are not usually run towards a reference point ....
    The best solution is to create subfolders and to distributed the files so that the maximum number of each folders is not exceeded.
    Greeting cheese
