This is probably a really dumb question but my forte is not in Electronics
I am trying to wire this permament Magnet mount motor with this drive with 230VAC
I have everything wired up.... except the ground?!?! am I supposed to run this badboy with a rod straight into the earth?!!? Also I would like to have this under PC control eventually I have an encoder but I don't know how to wire it into the Control. Any help would be greatly appreciated! Thanks
Sean Breed
MM23001C Minarik Drives (can't link for some reason)
here is drive info
"# MM footprint: An extremely compact size in an industry standard mounting footprint.
# Speed range and regulation: 1% regulation over 60:1 speed range.
# User adjustable calibration pots: IR compensation, min speed, max speed, current limit, acceleration and deceleration.
# Diagnostic LEDs: LEDs for current limit status.
# Stopping modes: Coast to minimum speed with inhibit terminals (N.O.),decelerate to min speed through pot circuit (N.C). External dynamic braking can be added.
# Spade terminals: Easy to use, lower cost and able to fit in a smaller package.
# Additional features: Dual voltage AC input and field voltage for shunt wound motors."
