586,531 active members*
2,925 visitors online*
    Hello everyone!
    I am new here and have the following problem:
    I want to create a procedure on a Fidia M1 controller in which I want to place a piece zero point from a pre-defined register.
    The whole looks like this:
    RG 04 -120. ;coordinate X
    RG 05 -70. ;coordinate Y
    ORIGIN 1
    SET XM:04
    SET YM:05
    The last part (SET XM:04 SET YM:05) is the interesting part- what is the correct Syntax?
    I already tried various versions without success.
    Thank you in advance
    Regards
    michael
    ADDITION:
    The last part is the only register use of the procedure which DOESN’T WORK.
    All other usages (e.g. >G0 X:06 Y:07 – of course register set in advance!) are carried out without problems.
    So either there is no register usage indented for the command SET *M or there is a syntax error...
    Another attempt:
    Does t the M1 controller has another memory that I could set/read out for this operation?
    Regards
    Michael
    That doesn’t work with your software -unfortunately- it’s too old!
    From V3R10.0 the following works:
    (example for a useful usage of the register)
    G201H0
    RG 01 = 10000.
    RG 02 = 2000.
    RG 03 = 3000.
    RG 04 = 4000.
    RG 05 = 500.
    >G203
    N1 (Fidia S.p.A. ISOGRAPH v. 7.0.1 07/26/06 10:53:10)
    N2 (compile file: C:FIDIAProgramh1)
    N3 ( HIGH SPEED DRILLING)
    N4 ( T00 D 32.000 R 0.000)
    N5 M03 S2000 F:01
    N6 G00 X0.000 Y0.000 Z100.000
    N7 G00 X0.000 Y0.000 Z2.000
    N8 X0.000 Y0.000 Z0.000
    N49 X4.301 Y4.874 Z-0.135
    N50 X4.053 Y5.082 Z-0.143 F:02
    N51 X3.794 Y5.278 Z-0.151
    N100 X-6.299 Y-1.604 Z-0.540
    F:03
    N101 X-6.211 Y-1.916 Z-0.548
    N150 X5.990 Y-2.525 Z-0.937
    F:04
    N151 X6.108 Y-2.223 Z-0.944
    N200 X-3.250 Y5.629 Z-1.333
    F:05
    N201 X-3.527 Y5.460 Z-1.341
    N251 X-0.486 Y-6.482 Z-1.738
    F:01
    N5166 G00 X0.000 Y0.000 Z100.000
    N5167 M05
    Finally it’s possible to write translations, rotations and reflections per G command into the NC program. But as I said only from version V3R10.0 and higher...
    Regards Bert
    Hello Bert
    Thank you a lot for your answer.
    First I thought that my controller version cannot do what I am planning to do after what you wrote but my controller is definitely able to write rotations, reflections etc. into the NC program..
    Like this we get feeds into a subprogram..
    So is there still hope?
