586,395 active members*
2,852 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > GRBL Connecting Arduino UNO TB6560 Driver
    Dec 2011
    8
    Hope this hasn't been asked elsewhere on this forum. I have searched, but my searching skills may not be up to par.
    I'm trying to work out the connections between an Arduino UNO R3 running GRBL to a TB6560 stepper driver, specifically this one:
    TB6560 Single Axis 3A Stepper Motor Driver - Green (10~35V)
    The GRBL firmware has these outputs:
    - Spindle Direction
    - Spindle Enable
    - Limit Z
    - Limit Y
    - Limit X
    - Stepper Enable / Disable
    - Direction Z
    - Direction Y
    - Direction X
    - Step pulse Z
    - Step pulse Y
    - Step pulse X
    The Stepper Driver has :
    - EN +
    - EN -
    - CW -
    - CW +
    - CLK -
    - CLK +
    I've got the motors hooked up on the other end, just cant work out these connections.
    Any help would be greatly appreciated.
    Jan 2010
    2141
    Re: GRBL Connecting Arduino UNO TB6560 Driver
    There are at least a couple ways to hook it up, but this should work:
    - EN + Stepper Enable / Disable
    - EN - Ground
    - CW - Ground
    - CW + Direction X (if you're using this driver for the X axis, otherwise choose a different direction axis signal)
    - CLK - Ground
    - CLK + Step pulse X (if you're using this driver for the X axis, otherwise choose a different step pulse axis signal)
    Dec 2011
    8
    Thanks!
    This helped. Couldn't for the life of me find these connections anywhere.
  1. Connecting a Controller Board
    By kpkale in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-29-2007, 03:16 PM
  2. Series connecting PS caps?
    By jevs in forum CNC Machine Related Electronics
    Last Post: 03-28-2005, 05:20 AM
  3. Connecting Amp Enable
    By keithorr in forum CamSoft Products
    Last Post: 03-22-2005, 12:31 AM
  4. Connecting Two Power Supplies
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 03-19-2005, 01:03 AM
  5. Need help connecting laptop to CNC
    By flyguy1254 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2004, 12:28 AM
