586,576 active members*
3,404 visitors online*
    Jul 2014
    shuttle motor problem
    Hi all.....
    warm regards from Indonesia..
    I have HAAS cnc Minimill and the problem is shuttle motor can not moving (suttle in) properly.
    I'm already check the power is on,but the motor just a little bit move and alarm appear.
    if i knocking the arm,sometimes motor running but sometimes breakdown again and alarm appear again.
    For information,i have replace the I/O PCB and motor running well,but 3 days later this problem is happening.thanks
    Feb 2010
    1184
    Re: shuttle motor problem
    Quote Originally Posted by totok View Post
    Hi all.....
    First, do a search on this site as this topic has been discussed many times, so you should find a lot of useful information to help troubleshoot.
    That said, check the motor brushes and shuttle switches.
    Good luck!
    Jun 2004
    43
    I have one Haas with the shuttle type tool changer, I don't know if it is similar to the one on your mill or not but I suspect it is. When I do a lot of heavy face milling it will throw large coarse chips up on the carriage in the rear and eventually jam the roller cam arm up, and then it will not move far enough and then it alarms out. I would check that as a possible cause also.
    May 2012
    67
    Totok,
    This could be caused by the shuttle motor, motor clutch, tool changer relay or I/O board. Give us more info please.
    Thank you,
    Phil
  1. 320X motor voltage problem, motor is unpowered by drive
    By RustedOut in forum Gecko Drives
    Last Post: 03-15-2013, 05:57 AM
  2. Shuttle Pro Problem
    By shane.vella in forum Mach Wizards, Macros, & Addons
    Last Post: 07-16-2012, 01:17 AM
  3. Jog shuttle quirk
    By Tinkertect in forum Tormach Personal CNC Mill
    Last Post: 01-27-2011, 07:08 AM
  4. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  5. Shuttle In Problem
    By CountBraden in forum Haas Mills
    Last Post: 08-24-2008, 05:57 AM
