LC1325M is a mixing cutting machine, specialized in cutting stainless steel, carbon steel, MDF and acrylic.
High efficiency: The cutting speed of 1mm stainless steel is 1800 mm/min.
20mm acrylic with perfect cutting quality.
LC1325M machine is matched with the Panasonic Servo System and high precision.
ball-screw system to ensure the high precision, running stable and long-operation.
The sheet metal is not flat. But the system can sense a distance from the nozzle to the metal surface and follow the surface up and down to automatically adjust the certain focus distance for keeping high precision cutting quality.
The laser beam is expanding, so the bigger the working area is, the more difficult the machine is to get the same cutting quality over the whole working area. The fixed beam optical system can guarantees the consistent beam power and quality over the whole working area so that the machine can get the same cutting quality.
High efficiency, high precision, stable performance and long life.
Low running cost about 5KVA/hour.
Features
Laser tube (150w)
High precision ball-screw system
Untouched following system
Fixed beam optical system
Industrial chiller
Off-computer controlling system
Application
Laser power
150w
Material
Acrylic
MDF
Stainless steel
Carbon steel
Cutting thickness
30mm
10mm
1.5mm
1.5mm
150W Cutting speed
Material
Cutting thickness
Cutting speed (mm/min)
Stainless steel
0.5mm
2700
1mm
1800
1.5mm
1000-1200
Carbon steel
0.5mm
3000
1mm
1800
1.5mm
1000-1200
Acrylic
10mm
300
20mm
90-120
MDF
10mm
300-400
Technology Parameter
Model
LC1325M
Laser power
150W
Working area
1250 × 2500 mm
Positioning accuracy
±0.05 mm
Positioning speed
20m/min
Weight
1000 kg
Power supply
220V±10%/10A
Attachment 241444Attachment 241446
Quiven from G.weike laser
skype: wkquiven
[email protected]
