586,655 active members*
2,511 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Another Mill - Haas, Another Tormach, or a Novakon?
Page 3 of 6 12345
Results 41 to 60 of 107
  1. #41
    Jul 2004
    1424
    Re: Another Mill - Haas, Another Tormach, or a Novakon?
    Wow that Brother S2N is a clean looking VMC. Brand new? bet you like it. That is on my list of machines I watch for coming available on the second hand market. Impressive moves in that video.
  2. #42
    Jun 2008
    1082
    Did you settle on a new machine?
  3. #43
    Sep 2012
    1543
    Nope, some things came up and I need to hold on to the money for now. I'm almost thinking a good lathe cam would produce more money than a second mill. So far no luck on finding good CAM that is affordable. Rhino Turn didn't work out and I got a refund.
  4. #44
    Jan 2007
    869
    If you really need a nice simple lathe cam, check out Dolphin CAD/CAM. Their lathe software is fantastic.
    Wade
  5. #45
    Nov 2007
    2151
    Quote Originally Posted by tmarks11 View Post
    wow Ninja fast z moves in that video
    Quick look at specs tells me it would cost about $0.80 an hour to power such things at residential rates here. Yet alone on demand power meters.
    md
  6. #46
    Sep 2012
    1543
    Dolphin didn't look very good when I last looked at it a year ago. Do you use it daily? Have any YouTube videos of it?
    Power in my town is $0.13 per KWH, which is about double of the national average I believe. Because a machine says 30hp, doesn't mean it uses all 22,000+ watts...
  7. #47
    7063
    Quote Originally Posted by BAMCNC.COM View Post
    Here in CA, we pay 2-3X that....
    Ray L.
  8. #48
    Jun 2006
    3063
    Have you looked at SprutCAM for turning ops? I've been playing with that a bit while waiting to buy a CNC lathe and once you get past the usual frustrations SprutCAM seems to foist on the user it seems to be pretty capable. I've virtually no experience with other CAM software, though, so it might not be near as capable as other programs. Tough to beat the price, though, unless you need to run a multi-machine shop full time where higher cost competitors might make more economic sense.
    Mike
  9. #49
    Jul 2006
    525
    Quote Originally Posted by mountaindew View Post
    md
    If its running hard enough to be draining $0.80/hr in power costs, its likely making someone around a $150/hr shop rate
    Most turning CAM license the same modules, and as such produce identical or near identical code.
  10. #50
    Jun 2004
    6618
    I use Dolphin for the little I do on the lathe. Works pretty good. Rudimentary GUI, but serviceable.
    Lee
  11. #51
    Nov 2007
    2151
    $0.195 per kw here
    And my power bill is extreme this time of year and a reason for the silly comment mostly because of the cost to cool home and shop
    Also that machine is not going to work well in a barn! imho you need a fully climate controlled room or building to best results anyway !
    and for fun we can do some math.
    hass mini mill specs
    6 hp at 50% is what 3000 watts per hour right?
    servos of 700 watts each = 2100 watts per hour
    controller and electronics, drivers....... say 400 watts
    total of 5500 watts per hour div by kw = 5.5 kw an hour x 0.13 = 0.71 per hour of power
    and don't forget poor people that pay demand power!
    declare war on more coal power plants and we will be paying even more imho
    another thing even my tormach adds an easy 1000 watts of heat to my shop per hour. and a.c has to pump out . along with lights and other things it adds up.
    no free lunches I guess
    md
  12. #52
    238
    Manitoba hydro.
    Energy Charge: First 11,000 kWh @7.752¢/kWh
    Next 8,500 kWh @*5.381¢/kWh
    Balance of kWh @3.552¢/kWh
  13. #53
    Jul 2007
    675
    Quote Originally Posted by rlockwood View Post
    try solidcan if you can swing a Solidworks license.
  14. #54
    Jun 2008
    1082
    I'm not sure about that exact model, but modern Brother drill and tap centers regenerate power while decelerating - uses less power and creates less heat too.
  15. #55
    Feb 2011
    605
    Thats the new Speedio model that does that. The S2D at my work does not do that. Mmmm Speedio.....
    PM-45 CNC conversion built/run/sold.
  16. #56
    Sep 2012
    1543
    I haven't looked at sprut at all actually. Will check it out.
    I have a climate controlled garage MTD
  17. #57
    Sep 2012
    1543
    Can you guys check your Turning Posts and see if they can post for a Fagor 8025
  18. #58
    Nov 2007
    2151
    From what I see in your videos, you have a very capable place to fab and stage your projects.
    md
  19. #59
    Jun 2006
    3063
    I don't see one in mine (SC7 or 8) but may have deleted some of the ones that came with SprutCAM.
    Try:
    SprutCAM America - Home
    SprutCAM forum (Powered by Invision Power Board) Dave there of UK Sprut is pretty knowledgeable
    SprutCAM — CAM Software Solution for Your Manufacturing Needs
    SprutCAM does come with a post editor so you can create your own, possibly based on an existing post to save time. I think that Sprut will customize one for you, but don't know what they charge, if anything. Dave in the UK at the second link may also provide that service and would probably be a lot easier to communicate with as would Eric at SprutCAMAmerica.
    Mike.
  20. #60
    Jul 2006
    525
    HSMworks does include a generic Fagor post, though its designed as a milling post and would likely need modified to work.
    Ray can attest to the awesomeness of their post processor system.
    Its awesome..
Page 3 of 6 12345
  1. Tormach 1100 S3 using Tormach 1.5" face mill....
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 05-06-2015, 04:50 AM
  2. Tormach v. Novakon - Opinions?
    By sansbury in forum Tormach Personal CNC Mill
    Last Post: 06-06-2013, 04:20 AM
  3. Tormach TTS vs Novakon vs Smithy
    By TangentAudio in forum Benchtop Machines
    Last Post: 02-03-2013, 12:38 AM
  4. Replies: 32
    Last Post: 12-26-2012, 03:29 PM
  5. Novakon nm-200 or tormach pcnc 1100?
    By rppman in forum Novakon
    Last Post: 12-14-2010, 07:26 PM
