587,033 active members*
3,342 visitors online*
Results 1 to 7 of 7
    Jan 2012
    57
    Source for AC bearings / belt drive conversion
    Hi guys, my belt drive is about to ship from ArizonaVideo.
    He recommended AC bearings, specifically the Koyo or Nachi 7206 BGC3.
    His mail seemed to indicate that they come as a set 7206/7207
    Found one on amazon
    Koyo 7206BGC3 Angular Contact Ball bearing: Amazon.com: Industrial & Scientific
    Found a bunch more on ebay... I think my search is getting close to fruition.
    Dave's exact recommendations were:
    top, (koyo) 7206BGC3 FY S0607
    bottom, (koyo) 7207BGC3 FY S0605 35mm x 72mm
    Where did you guys source your bearings for the belt drive conversions?
    For this purpose are there material differences between the million different types of 7206 and 7207?
    Anyone have luck with the Nachi ? Found those here:
    7207 Nachi Angular Contact Bearing 35x72x17:Steel Cage:C3:Japan: Amazon.com: Industrial & Scientific
    7206 Nachi Angular Contact Bearing 30x62x16:Steel Cage:C3:Japan: Amazon.com: Industrial & Scientific
    thanks in advance, I am a total bearing noob.
    Jan 2012
    57
    Re: Source for AC bearings / belt drive conversion
    Well, I found this online (in brazil, but thankfully not in portugese):
    http://www.koyo.com.br/upload/koyo/c...20Bearings.pdf
    200 pages of detail, time to get reading...
    Dec 2013
    290
    I have the nachi bearings from amazon, they seem to work well so far.
    Jun 2013
    41
    Try VXB. Ball Bearings:Miniature bearing:Ceramic Ball Bearings:Flanged Bearings
    They have a good selection and decent prices. If you need to talk with someone face to face, your best bet is to find your local bearing supplier (like BDI).
    KIND. ATTN. –PURCHASE DEPARTMENT AND PRESIDENT
    DEAR President and manager , GOOD DAY
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERS OF Precision Bearings use for CNC and Machine tool ,AND Radial-Axial bearings WHICH ARE MAKE OF Wafangdian Tianjiu Bearings Technology Co.,Ltd.
    WE ARE IN THIS BUSINESS SINCE LAST FIFTEEN YEARS; IN THIS SPAN OF TIME WE HAVE SUPPLIED PRECISION IN ALMOST ALL THE CONTINENTS OF THE WORLD.
    BESIDES, WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THE PRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    FEATURED BY HIGH PRECISION, LOW NOISE, HIGH ROTARY SPEED, HIGH QUALITY AND LONG SERVICE LIFE, OUR PRODUCTS SAVE USERS’ COST AND SHORTEN PURCHASE TERM. WIDELY APPLIED TO COMMON MACHINE TOOLS, CNC MACHINE TOOLS, LARGE / MIDDLE MOTORS, PRECISION ROLLING MILLS, ETC., OUR PRODUCTS FILLED THE DOMESTIC BLANKS AND CAN SUBSTITUTE IMPORTED PRODUCTS.
    THIS IS TO INFORM YOU THAT WE HAVE PRECISION BEARINGS AND OTHER GOOD QUALITY BEARINGS AVAILABLE, CAN SUPPLY FOR YOU WITH BEST QUALITY.
    WE HOPE CAN CORPORATION WITH YOUR COMPANY.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    THANK YOU !
    REGARDS!
    Lixingwen(栗星文)
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: http://www.wzfb.cn
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
    Jan 2012
    57
    Thanks guys. I have some koyo bearings in hand now.
    Do I need any particular kind of grease, or can I get some grease from ace hardware?
    If it matters, desired RPM was between 6 and 7k.
    Oct 2008
    2100
    I would use a high speed bearing grease. Kluber and Dow Corning both come to mind.
    In fact I think I would use a high speed bearing grease on any spindle rebuild. The typical wheel bearing in a car doesn't turn over 1000 RPM for most of its lifetime. Maybe a compact with 13" wheels that is speeding does. While I am sure that wheel bearing grease or other automotive grease would last for a while, the high speed bearing greases are formulated to run at the much higher speeds.
    There is a reason cars run oils in their high speed parts instead of grease. (actually a lot of reasons, but in this context...)
    Bob La Londe
    http://www.YumaBassMan.com
  1. belt drive conversion
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 08-26-2014, 05:36 PM
  2. Belt Drive Conversion
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 01-15-2013, 07:04 PM
  3. Can I still get an X1 belt drive conversion?
    By Fast01 in forum Benchtop Machines
    Last Post: 10-09-2010, 02:21 AM
  4. X2 belt drive conversion
    By port_huon in forum Benchtop Machines
    Last Post: 03-11-2009, 09:29 AM
  5. Belt drive conversion for X3?
    By phantomcow2 in forum Benchtop Machines
    Last Post: 07-17-2007, 12:31 AM
