586,477 active members*
3,587 visitors online*
    Jun 2014
    40w ebay Laser - LaserDRW program woes
    I just picked up an ebay laser last week to mess around with some simple stuff mainly for small parts for prop manufacturing and name tags. I've got the laser setup but have yet to get it to work because the software isn't setup correctly and the manual is in chinese.
    I've installed the WindsealXP software and got it to recognize the usb dongle key but it says I'm using the wrong device ID. I've tried the number on the circuit board and the one that came in the manual to no avail.
    Jul 2014
    19
    Re: 40w ebay Laser - LaserDRW program woes
    after i installed the software i had the same problem untill i turned off the laser and back on and restarted the software again and was able to select the device
    Oct 2014
    Hello Ryan,
    I'm Jean-Louis. Wondered if you ever got your device-id problem on your laser engraver. I have the same problem on the device I purchased. Device Id on the mboard, the ukey and the software are all the same, but I am getting a invalid device-id error.
    Thank you
    Jul 2014
    19
    try this go into your preferences of the laser and select the device that says 6c**** M2 then reboot computer while laser is still on see if that works for you
  1. CorelLaser/LaserDRW extremely inefficient paths
    By BitcoinWallets in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2014, 12:18 PM
  2. Laser Tube off Ebay?
    By dafatboy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2012, 01:40 PM
  3. Laser bargains on ebay, or are they?
    By Konstantin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2008, 08:57 AM
  4. Synrad CO2 Laser available on Ebay
    By nelsonzjax in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-07-2006, 09:50 PM
  5. Synrad 10W Laser Available on Ebay
    Last Post: 12-07-2006, 08:36 PM
