586,679 active members*
2,832 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Radius to end of arc differs from radius start
    May 2003
    132
    I am having trouble getting Mach3 to do a profile cut using Dolfincam. I get a Radius end of arc differs from radius start. I'm using the T_Mach3DCSS post processor. I'm cutting a ball on the end of a rod. Any Help would be greatly appreciated.
    Donald Clifton
    Re: Radius to end of arc differs from radius start
    Change the IJ mode in General Config and see if that fixes things.
    May 2003
    132
    Thanks Ger, That's the first thing I tried. Do you use Dolfincam? Your always real helpful.
    Don Clifton
    May 2007
    428
    Don, I just emailed you 2 different posts to try (one for radius and one for diameter).
    Dolphin CAD/CAM Support
  1. 021 start radius end radius error
    By XAD in forum Tree
    Last Post: 06-01-2012, 04:59 PM
  2. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  3. Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-10-2010, 03:16 AM
  4. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  5. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
