586,384 active members*
3,738 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC15 WILL NOT LEVEL
Results 1 to 6 of 6
    Dec 2006
    49
    That isn't entirely true. It will level but when it is, the right front foot is off the ground. tried everything i can think of but no joy. Thinking about clamping the rt front foot to the floor and working around it. Any suggestions?
    May 2014
    43
    Re: VMC15 WILL NOT LEVEL
    Shim it?
    Dec 2006
    49
    I can make the foot touch the floor but if it does it throws off the level in both x and y. The base is a weldment and clearly it is racked. It could have been like this for 20 years. Previous owner of this business never checked service tech's work and thought PM was something that happened after lunch. Hoping someone else might have run into this before.
    May 2014
    43
    Sorry I misunderstood .
    Dec 2006
    49
    Well it turns out that it really won't level! For what ever reason the weldment base is racked. If it came that way from Fadal or is a result of sitting cock-eyed for 15 years is unknown but at least I'm not crazy.
    BJ
    Most of the time when I see this its because the floor is not level, but I am not in your shop so I dont know for sure. Shim the pad, and get table level close, but there is a lot more to machine geometry than just a level table. Use a magbase and indicator to check squareness in XYZ plane and tram the table. A cylindrical square is very helpful in setting machine geometry. You may have to shim the spindle, the instructions for this are available online.
  1. Fadal VMC15 & DNC
    By rjdj2000 in forum Fadal
    Last Post: 06-18-2020, 06:37 PM
  2. Hello... moving a VMC15
    By Sherri in forum Fadal
    Last Post: 12-11-2009, 12:59 AM
  3. DNC Help Please on VMC15
    By FastFieros in forum Fadal
    Last Post: 04-22-2008, 06:21 PM
  4. Vmc15
    By multex1 in forum DNC Problems and Solutions
    Last Post: 04-17-2007, 10:13 AM
  5. Where to buy VMC15 relay
    By melzer in forum Fadal
    Last Post: 02-11-2007, 04:36 AM
