586,655 active members*
2,808 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Lock Tool Numbers?
Results 1 to 7 of 7
    Aug 2013
    Lightbulb Lock Tool Numbers?
    I've been dabbling in mastercam x6 for some time now (maybe 6 months) and I've figured out just about everything I need to be able to do with it without too much difficulty, save for one thing..
    I'm using the Import/Export feature to save entire sequences of tooling (I frequently use the same tool sets for many operations) but for whatever reason I can't find a way to lock the tool numbers in. For example, if I have an endmill in tool slot 8 on my machine, the import function will renumber it to slot 1 if there are no other tools already on the job.
    Perhaps I'm using the incorrect function for saving tool sequences, or I'm missing something? In any case, if anyone has suggestions I'd love to hear em :P
    Oct 2010
    33
    Re: Lock Tool Numbers?
    Not sure if you have figured this one out or not but here's how to change this.
    -Go into your machine definition.
    -Then go to Edit the control definition
    - under the control topics pick "tool"
    In this menu you will see two options "add to tool" and "from tool" toggle the from tool option and save.
    Cheers
    Jul 2003
    263
    in the Machine Group Properties under Tool Settings uncheck the box for "Assign tool numbers sequentially"
    see attachment
    If you can ENVISION it I can make it
    Oct 2006
    104
    I have talked to our re-seller a number of times on this issue. At this time there is no way of locking the tools to a certain number.
    Jul 2003
    263
    Quote Originally Posted by seijack View Post
    your reseller obviously needs more training in the product he is selling
    Oct 2006
    104
    What I asked is if you could lock the tools numbers so that you could not re-number them, while re-numbering all other tools. The answer was no.
    Dec 2008
    3111
    Quote Originally Posted by cnc-king View Post
    Your reseller needs to be a little more current with the product....
    You need to checkmark what cnc.king put up in his 1st reply
    - utilise a tool library that replicates what (standard) tooling you have in the machine carousel as to tool numbering ( not by pot ), build lengths & so on.
    you then load this into each session before adding any additional tooling ( errors will display if duplication occurs )
    Edit a tool library correctly so that any tooling imported, contains the required cut data ( F,S DOC, step over, coolant etc), all that is then required is to assign a tool number for this session
    - train yourself to use this method for tooling search of similar sizes ( ie 10mm cutter required, select a 3/8" flat endmill, then modify the cutter diameter....all other data will be close for that material)
    -----editing a library can be a bit involved, as a different lib would be needed for each material type ( ie Steel, Alum, Titanium, Wood, etc)
  1. SprutCAM Tool Library tool numbers
    By MichaelHenry in forum SprutCAM
    Last Post: 06-29-2016, 02:30 PM
  2. Negative tool numbers
    By declanhalpin in forum MadCAM
    Last Post: 02-14-2013, 07:56 PM
  3. Lock out tool release
    By SBC Cycle in forum Haas Mills
    Last Post: 12-19-2012, 06:19 PM
  4. Tool Numbers - recommendations?
    By Scott Kelley in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-29-2009, 04:26 AM
  5. Tool Numbers
    By Mike Mattera in forum EdgeCam
    Last Post: 02-04-2008, 05:18 PM
