586,905 active members*
3,167 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF2 with 185 a cable fault
    Jul 2010
    7
    I am getting an occasional 185 a cable fault alarm. Typically we can hit reset and clear the alarm and are able to run again. Sometimes it runs for hours without this alarm, sometimes it happens a couple of times per part.
    I have replaced the cable and still have the same problem. I am hoping that someone has some things to check so I don't just throw parts at this.
    Mark
    Mar 2010
    1852
    Re: Haas VF2 with 185 a cable fault
    Assume we have no idea what year machine you have, when the alarm comes on, what that alarm means. Oh, we don't. More details would sure help out in diagnosing the problem.
    Mike
    Sep 2006
    48
    185 is A axis cable fault. On a rotary the cable is subjected to a pretty harsh environment so a visual inspection must be done there first. The 185 alarm stems form a total loss of the encoder signal. The number one cause of this alarm is incorrect setting 30 or incorrect parameters. These will need to be checked first.
    If parameters are good and you have a brush motor there are two connections for the encoder. One at the encoder and a second at the cable junction. If your unit is brush, there is one at the motor or one at the cable junction. With the unit unplugged remove the cable from the indexer and check the connections. If the cable and connections look OK you will need to go deeper.
    In both cases the encoders operate from 5vdc. In most cases it is a loss of this voltage that causes this alarm. The small red wire going to the encoder supply's the 5vdc.
    Good Luck
    Slammer
  1. X axis cable fault
    By steedspeed in forum Haas Mills
    Last Post: 09-02-2011, 04:20 PM
  2. 233 Jog Handle Cable Fault
    By Machineit in forum Haas Mills
    Last Post: 07-28-2011, 04:02 PM
  3. '08 vf3 spindle cable fault
    By ndrew2505 in forum Haas Mills
    Last Post: 01-04-2011, 02:43 PM
  4. spindle cable fault on VF-3
    By stefan2108 in forum Haas Mills
    Last Post: 07-18-2007, 07:26 PM
  5. Haas VF3 Y cable fault error - advice?
    By JHR1 in forum Haas Mills
    Last Post: 05-28-2006, 02:05 AM
