586,389 active members*
3,228 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Replacing old Fanuc AC Spindle Drive with Delta VFD-E and Arduino
Results 1 to 20 of 52
Threaded View
    Jul 2008
    156
    I'm replacing a Fanuc A06B-6044-H007 AC Spindle Drive in my 3 Axis Vertical CNC machine with a Delta VFD-E in my shop. I've been gathring information for the last year in preparation for this project and am surprised at how little information I could find.
    I started this thread to help document how to replace an old Fanuc Spindle Drive with new VFD technology. Also, ask a few questions, and hopefully get some answers.
    In this machine I bought last year, the Fanuc spindle drive goes into an alarm state after running it for about an hour. I would have to let it sit for a while and then power it back on and run it for another hour. While we could dive into why the Fanuc Drive was misbehaving or how to repair it, I would like the purpose of this thread to stay on topic of replacing Fanuc AC Spindle Drives with newer VFD technology drives.
    All code that we used to do this is Open Source. I hope that it will help someone else or someone will take this code and make it better.
    The main project Kicked off tonight.....All the communications have been figured out. We programmed an Ardiuno MEGA to mimic a Fanuc Spindle drive and plugged it into the Fanuc 6M controls. We wanted to see if we could talk back and forth to the Fanuc 6M Controls and make the control think it was still connected to a Fanuc Spindle Drive. That was the relatively easy part, and we overlooked how to set parameters on a VFD to run a motor. No one here has a good understanding of that.
    At one point we had the drive running the spindle motor up to a pretty good speed. But it was challenging to find any settings for the VFD to make it run the motor up to speed. Most of the time (including where we are at now) the motor starts to spin but never gains RPM. You can hear the VFD changing pitch like it is trying to ramp the RPM up, but then it will either over torque or pull a very large number of Amps for longer than I am comfortable letting it draw that much power and not be changing RPM.
    Is anyone familiar with the basic motor settings for a Fanuc Model 3 Motor? I have some of the basics covered, I know it is
    Fanuc Model 3 Spindle Motor
    200V
    3.7kw/5.5kw (Continuous/30 minutes)
    17Amps/22Amps (Continuous/30 minutes)
    4 Pole
    3 Phase
    Insulation: Class F
    RPM 1500/6000
    Amb Temp 40 degrees C
    We do'nt know how to set the Delta VFD-E Drive to accurately run the Fanuc AC Model 3 Motor. It seems to be having a really hard time getting it going. Here is what we have:
    Delta VFD-E
    Model# VFD055E23A
    7.5HP/5.5kw
    Three Phase 230V
    We have the communications covered like FWD, REV, Zero Speed, etc, and are receiving and sending all the corect signals back and forth between the VFD and the Fanuc controls, but we need help tuning the motor using the Delta VFD.
    Attached Thumbnails Attached Thumbnails Delta and Fanuc AC Spindle Drives.jpg   Decoding the wires on CN1 on Fanuc Spindle Drive.jpg   DSC07876.jpg   DSC07875.jpg
  1. Replies: 2
    Last Post: 06-23-2014, 07:59 AM
  2. Replies: 10
    Last Post: 08-20-2013, 12:50 PM
  3. Meldas Replacing Spindle Drive
    By Jack2012 in forum Mitsubishi controls
    Last Post: 07-25-2012, 06:46 PM
  4. Replacing Fanuc AC Spindle Drive
    By barchdesigns in forum Fanuc
    Last Post: 04-22-2012, 06:35 PM
  5. 1986 qt10 getting rid of hi/low unit and replacing spindle drive
    By carbidecraters in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2009, 11:10 PM
