586,275 active members*
3,233 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How was this inside chamfer made?
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Jun 2004
    6618
    Re: How was this inside chamfer made?
    You are both arguing semantics. It can be done either way, but like I mentioned, neither is as easy as it might seem at first glance. It can be machined in 3D format using various tools. Long cycle time for some mills.
    It can be made from standard billet and then the beveled profiles mitered and epoxied in place. Much shorter machine time.
    And it can be cast.
    For a one off with some hand finishing, 3D machining and finishing with a mill drill and a tiny ball end mill might be the easiest and cheapest. Isn't that the results that the OP requested?
    Lee
  2. #22
    Jun 2007
    3891
    Quote Originally Posted by LeeWay View Post
    And it can be cast.
    semantics? err. no.
    the OP asked how THEY made it. He is arguing that the piece is a die cast off the shelf part. it is not. it is a hand machined part from the ILM prop shop. milled, filed, ground, bondo'd, painted. they didn't have cnc, or edm, or die casting. actually im shocked its even made of metal.
    how the OP goes about making his OWN? that's easy. you can cnc it very easily with tapered ball end mills or using a v-carving strategy..
  3. #23
    Jun 2004
    6618
    Semantics.Er yes. You are both using each others words with your own interpretations of what the other meant. Both positions have validity. What needs work is tactful presentation in a debate.
    Lee
  4. #24
    Jun 2007
    3891
    arguing semantics means we are both saying the same thing different ways. that's exactly the opposite of whats going on.
    I gave up on polite debate years ago. ive got him on ignore actually, but occasionally his presence interferes with my day.
  5. #25
    Jun 2004
    6618
    You both are arguing different ways of achieving the same thing. Not precisely semantics unless you are a third party reading it.
    Lee
  6. #26
    238
    I gave up already. Semantics or not. You just can't be right for some people. My take, it was machined.(period).
  7. #27
    Mar 2006
    2712
    Er..... Maybe a Bridgeport manual mill with a "cherrying" head or shaper attachment???
    Dick Z
    DZASTR
  8. #28
    Jun 2007
    3891
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    what is that? pics?
  9. #29
    15362
    Quote Originally Posted by ihavenofish View Post
    what is that? pics?
    There were many different Heads made for Bridgeport & other manual mill, the Cherrying head would not do it, But the Shaper Head would do it
    Mactec54
  10. #30
    Jul 2011
    Wow a little bit of drama! I do believe it was milled on a manual milling machine but not die cast.
    It's not ILM but Don Pennington. IMDB.com him. I do have his email and will ask him soon. I think there could have been some hand finishing for the sharp edges or tiny ball end mills etc.
    I'm about 90% sure it was not "off the shelf". No real buttons, just leds behind a plastic sheet. It looks like a membrane switch but nope. Thanks for all the info, I will post an update real soon.
Page 2 of 2 12
  1. American-made, AGNI laser controller made by Solustan Inc.
    By Rolf_K in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 09:32 PM
  2. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  3. Need some parts made in aluminum, have made wooden prototype.
    By Speedy55 in forum Want To Buy...Need help!
    Last Post: 12-05-2012, 03:51 PM
  4. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 06:27 PM
  5. Made in Australia (Made in taiwan, china)
    By carbidecraters in forum MetalWork Discussion
    Last Post: 01-10-2006, 09:05 PM
