Actually no. PID has to do with servo feedback to help keep on the desired trajectory. In your case you have no feedback. The parameters you have marked #1, #2, #4, #5 all have to do with feedback and can be ignored until you add feedback (encoders). The thing we are currently concerned with is the trajectory. Sometime called motion profile. This is sort of like planning a route on a map. It consists of your desired position, speeds, and times along the route on a theoretical basis. If you were to actually do the route then the actual path may differ from the original planned route. And if you somehow knew you were going off the planned route you could make corrections to get back on route.
