Hello,
I have a huge 100 watts laser cutter and I use lasercut 5.3 to control it, Ive recently started cutting 6mm black plexiglass, at first I could get a clean perfect cut at speed 2 and power 100% but now when I try the same speed and power I get bumpy cuts and not smooth cuts with the same material.
what is the problem?
what should I do?
Thank you
