586,708 active members*
2,477 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Newb Question - How to touch off work coodinates with Fanuc
Results 1 to 7 of 7
    Jan 2014
    57
    I've made the leap from Mach3 to a Fanuc 0M control and I have the manual but the Fanuc and VMC manual is terrible IMO for describing various procedures/ops, it makes a lot of assumptions on experience.
    In Mach3, unless I was doing something that required precise location using an edgefinder, I would just jog the axis's to put the center of the endmill above the "part origin/datum" and press the home buttons on each axis. This would zero out my work coordinates and be the 0,0,0 point my program started from.
    What's the equivalent "work/part zero" procedure on Fanuc? When I start the machine I flip the "return to zero" switch and press the "+" button and zero out each axis, but that is just taking it to machine zero. When it is time to cut a part and want to create "part zero" and I jog the endmill to what I want to be "0,0,0" what do I do to set that? Is there a button I'm overlooking or do I have to key in a command for it?
    Jan 2014
    57
    Re: Newb Question - How to touch off work coodinates with Fanuc
    Maybe I should clarify... I understand the control has work offsets, which basically creates the work coordinate system. I know I can manually enter the machine coordinates to G54. What I am wondering is there an easier way, where I can just put the tool at 0,0,0 and key something in that will zero everything to that datum?
    Also, when I setup a program to drip feed I presume I set the datum/origin to G54 and then preface my drip feed code with G54?
    Feb 2009
    6028
    Not the correct way really, but you can MDI a G92X0Y0Z0. I'll use that once in a while for setting up the ballbar.
    sent from me
    Jan 2014
    57
    See that's where I get confused... I keep reading to avoid using G92 to set the work origin. So if that isn't the right way, what is the right way? I don't have the "measure" softkey like I've seen mentioned in other posts, so do I have to write down the machine coordinates, convert them to inch (my machine coords are in metric, everything else inch), then enter them in one of G54-G59?
    If so that would be a nightmare to do that every cycle because I use a vise and not precise fixtures where I can just load in new stock and reuse the same offset.
    Sep 2011
    78
    maybe you could use "work shift" to calculate your piece zero
    put z0 in G54
    mdi G54 T0101 G0 U-1W-1
    scratch face of workpiese in jog and stay here
    [OFFSET], keep pressing soft key right [>] , [WORK SHIFT] move with cursor to INPUT Z type 0 (or 1 if you want to face of 1 mm of the piece)[input].
    this places you G54 zero point on the face of the piece.
    be carefull G55 etc. are shifted the same amound as G54 is shifted
    2932
    Quote Originally Posted by duivenhok View Post
    put z0 in G54
    Since he's stated he's got a 0M, I doubt that he has Work Shift.
    2932
    In thinking back to my 0M days, I seem to remember moving to the 0 point and typing MX0 INPUT and MY0 INPUT (Measure X0, Measure Y0).
    But it was a long time ago and I'm old... I could be way off base.
  1. NOT A NEWB BUT THIS IS A NEWB QUESTION
    By BOATDUDEGUY in forum Mastercam
    Last Post: 05-15-2012, 09:38 PM
  2. using machine coodinates
    By nc novice in forum G-Code Programing
    Last Post: 07-23-2010, 09:12 PM
  3. Question on using g10 for work offsets HMC Fanuc
    By Shotout in forum G-Code Programing
    Last Post: 06-25-2008, 09:49 PM
  4. Help With Work Offsets and Touch Off Probe
    By metx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2008, 04:31 PM
  5. Excel-4 Fanuc 10-m control question (newb)
    By Robert Miller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2006, 12:49 AM
