586,341 active members*
3,710 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Mikini/VFD conversion SWATH
    Aug 2010
    599
    Here is a concise documentation of my VFD conversion for anyone interested.
    Starting off here are the components I used (all the following from Automation Direct):
    Marathon 2HP inverter duty AC motor:
    Y551-A772 | 2 hp Inverter-duty AC Motor w/encoder: 145TC, 1800 RPM
    Durapulse GS3 3HP VFD:
    GS3-23P0
    GS3-FB encoder feedback card (since the motor has a Dynapar HS35 shaft mounted 1024ppr optical incremental encoder):
    GS3-FB
    10 pin encoder cable with military connector:
    TRDA-25CBL-VWD-10 | Connection Cable for TRDA-25N series encoders: 10-pin MS conn., 10 ft.
    300W 70ohm braking resistor:
    GS-23P0-BR
    There was a mishmash of Cat7 cables and Molex connectors
    12ga stranded wire from Lowes, and liquidtite 1/2" PVC coated flexible metallic conduit from Home Depot (with the connectors)
    http://www.homedepot.com/p/Southwire...-100346402-_-N
    The REX84 card that I designed, had printed, then soldered all the chips, resistors, LEDs, and capacitors onto.
    The motor mount itself that I designed and machined out of 6061-T6 Al:
    2 3D files in zip file attached to post
    The PMDX-106 Spindle control card:
    http://www.pmdx.com/PMDX-106
    Aug 2010
    599
    Re: Mikini/VFD conversion SWATH
    Crappy pic of the wiring (which I later realized wasn't completely hooked up. I must have taken the pic right before I replaced the VFD with a new one as I started undoing wires. I'll replace the pic with a current better one later when I get a chance. The wiring is the same though.
    Attachment 240416
  1. Mikini/VFD post-conversion cutting videos
    By SWATH in forum Mikinimech
    Last Post: 02-01-2016, 12:53 AM
  2. Tramming the Mikini
    By slowtwitch in forum Mikinimech
    Last Post: 10-04-2014, 12:27 PM
  3. ANYONE Own a Mikini Mech???
    By ejkosinski in forum Mikinimech
    Last Post: 02-06-2011, 06:29 AM
  4. CAD for the Mikini
    By choppero in forum Mikinimech
    Last Post: 01-11-2011, 08:16 PM
