587,030 active members*
4,102 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle will not orient at tool change
    127
    4020 fadal
    just started giving me fits..
    If I help the spindle turn, then it tool changes..
    Any hints in where I am at or wjat needs to be replaced,,
    Apr 2005
    1194
    We had a dirty encoder disk and had to take the fan off the top and carefull clean the rotor inside the encoder. I dont suggest this unless you are really carefull or run out of options. The syptoms we had were jittery spindle at 7000rpm+ in high range and 1700rpm-2500rpm in low range. My guess is that the encoder right behind the Z axis sheet metal is dirty. It stands vertical and I believe you can wipe it off and the area that rotates.
    Apr 2005
    1194
    But I believe their are two encoders...one for rigid tapping and one for spindle orientation. The rigid tapping encoder is at the top of the spindle and the one for tool orientation is in the middle of the spindle and faces either up or down (cant remember after the PM) you will need to clean it off. Try that first before you dig into the encoder. Dont worry you can try it with the sheet metal off.
    127
    carbidecraters
    Thanks for the help.. You were right on the money.. Just needed to do some unde the cover cleaning.. Orients like a new machine again..
    back to Chipsahow!!!
    Apr 2005
    1194
    HA GREAT NEWS!!!!
    I love it when a plan comes through... B.A. Barakkas -A team
