586,903 active members*
2,873 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Just got GibbsCam Advanced 3D, but I think I'm not doing it right. Let me explain....
    Jul 2006
    18
    I have a part I am cutting. It is a semi ellipse semi sphere as shown.
    Attachment 240040
    Now, if I take a regular contour pass using "contour" process with a regular square end mill, along the cross section of the profile tool, the machine will take a smooth pass, at the commanded feed rate.
    When I use surface flow cut to make the entire surface using the 3d cutting method and a ball end mill, the machine will take very similar passes following the xy contour of the part, but the motion of the machine is very jerky and with a commanded speed of 100 inches per minute, the machine MAYBE goes 20 inches a minute and keeps pausing for short times and then cutting again for bursts of time.
    Why does gibbscam program a nice machinable arc when it's a single pass, but during the surface flow cut, despite having only xy movements, with a step in z, the movements are very jerky and slow with lots of pauses.
    My thinking is that if I was to manually use the profile tool and do a .01" Z step from the top to the bottom and manually create all 180 or so passes along the z, it would work just fine.
    I know I'm missing something, so maybe someone could shed some light? Is there a way to use that same smooth arc pass but in mass quantity on several hundred z steps, but do it automatically with one of the surface or advanced 3d commands?
    Mar 2013
    17
    Re: Just got GibbsCam Advanced 3D, but I think I'm not doing it right. Let me explain
    That can sometimes be caused by the geometry of the solid model. Weird things can also happen with gouge protection turned on. Can you post some screens of your process settings?
    Dec 2008
    18
    I am having the same issues and it is quite concerning as it seems to be quite hard on the machine. Every software I have used in the past seems to output rather seamless linear moves and not very jerky point to point type moves. Could this be a post issue as well?
    Attachment 249290
    Aug 2006
    138
    It could be that at 100IPM the controller can't keep up. My 15M Enshu vertical can't keep up with code like that but my Toyoda with an 18i has no problem. Check the spline tolerance in "Preferences". Try increasing the tolerance and reducing the feed rate.
    Attachment 249996
    "Teach the ignorant, care for the dumb, punish the stupid."
  1. Help me explain why G54>G50
    By Timtucker in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2012, 04:49 PM
  2. could some one explain the following
    By derkiow in forum Stepper Motors / Drives
    Last Post: 12-16-2010, 05:30 PM
  3. Can someone explain G09
    By KLarson in forum WinCnc
    Last Post: 10-26-2010, 03:05 PM
  4. please explain
    By eloid in forum Linear and Rotary Motion
    Last Post: 02-13-2008, 10:30 AM
  5. Please explain
    By bearwen in forum Open Source Controller Boards
    Last Post: 02-19-2006, 05:07 AM
