the problem is that i am going for CNCFusion's kit.. and he uses nema 23 on X and Y axis .. and a NEMA 32 on the Z
AND it is direct drive...
i am confused what to do now.. maby i have to stick to "just" plain digital steppers..?
yes digital stepper is a good choice. Better than standard stepper motor...
the problem is that i need a stepper motor capable of around 7 NM on the NEMA 32 and around 3,5 NM on the NEMA 23 and i cant find that in the Leadshine closed loop easy servo lineup..
any other manufacturers of the same type of system? (closed loop)
if not, my backup plan is to revert to digital steppers
does anyone know what size steppers is required on the different axis?
i plan on using a CNCFusion deluxe kit
http://www.cncfusion.com
X and Y i plan on using 570 OZ-in / 4NM
Z i don't know how much i need 920 OZ-in / 6,5NM maby?
anyone have any info on this i would appreciate it
Thanks gozos! it is helpfull, i have searched but could not find any relevant info..
also i made another work bench.. need to clean up my part of the cave and finish the top part of the table so the mill is enclosed.. anybody got any good ideas?
thinking of using plywood and epoxy coating
Attachment 241288
one more also!
I have now ordered a KFlop and a KMotion to control and run my steppers.. steppers soon to be ordered...
Attachment 241294 + Attachment 241296 = Attachment 241298
Dynomotion KFlop
Dynomotion KStep
i have high expectations for it! and also Tom over at Dynomotion has helped me with finding out what would work best with the unit, a big thank you to him! =)
In this document from syil you can find this:
"Stepper motors:
Our X and Y axis stepper motors are a NEMA 23. They have a hold-
ing torque of 260 oz/in. And consumes 3 amps per phase.
Our Z-axis stepper motor is a NEMA 34 They have a holding torque
of 460 ounces per inch. And consumes 3 amps per phase.
And it seems it is direct coupling, no belt...
gozos @ Re: jossa's G0619, going CNC one step at a time
"Stepper motors:
gozos you are a life saver!
i think i will order this 570 Oz motor for my Z
and for X and Y i will use this 370 Oz motor
if that was good enough for syil then it should work on my machine
if you buy cnc fusion kit you need nema 34 for the Z...
Small-Mill Deluxe CNC kit PREMIUM BALLSCREWS
This Kit includes all the hardware for a 3 axis conversion. Two NEMA23 motor mounts for the table, and a NEMA34 mount for the Z axis, lovejoy couplings, timing belt and pulleys on Z-axis, locknuts on the X-Y ballscrews, ANGULAR CONTACT thrust bearings for X-Y axis, PREMIUM ZERO BACKLASH BALLSCREWS, and metric cap screws & bolts. Nema23 motor mount for Z-axis is available. You MAY need to modify your mill to install this kit. DELUXE BALLSCREWS HAVE A 5MM PITCH.
$969
so i think someone else has had the same idea before me...
so no problem!
yea i think this might actually work!
and the controller is capable of handling 5A per channel so i can go bipolar parallel and use 570 ozin/ 4Nm motors on all axis without problems!
only thing is i don't get the closed loop that a leadshine would give me..
got some new toys!
first i have gotten a IP66 enclosure for my electronics, Schneider Electric 600X400X200
Attachment 241698
and i have just received the Kflop and Kmotion..
(Kflop are going to be stacked on top of Kmotion)
Attachment 241700
the place that i was going to get steppers from had a bug in the checkout so i could not place an order.. so that is on hold for now)
Got both the Kflop (rev. 1.3) and the Kstep (rev 1.2) mounted together.
so far i love the hardware, the green terminals are detachable, making it much easier installing tthe cables, nice detail!
also i got a "free" USB cable included in the deal.. nice
Attachment 241758
Attachment 241760
Attachment 241762
Attachment 241764
so now i am reading trough the documentation on the hardware...
and to be honest it is a bit difficult to know where to start (they had included some printed documentation in the parcel tho)
and as far as i can see i need to download the latest software from here and after installing that, i have to check and see that my firmware is updated..
ok.. i have not updated any firmware yet.. (to afraid :P it kept saying i could brick the unit.. soooo... no )
the good thing is that i found out i need to disable driver signature checking routine on my WIN 8.1 pc.. so after doing that and installing the usb driver for the board, it connected! (confirmation in console)
so now i am connected to the Kflop, and i have 5V light on both the units, not sure if that is good considering that it is powered from a usb output on a computer but i can mess around in the programs.. now i need to read more manual to find out what is next.. (i think i need to define the outputs for my steppers and such but i will try to read the manual and find out what is next)
the enclosure is taking shape now..
i have also started painting it but i forgot to take pictures of that.
Attachment 242008
Attachment 242010
now my biggest problem is what to do with the front, i need something that is easy to access, but water thigh enough to withstand the spray of coolant from the machine.
i have also gutted the head and the back cover with all the controllers and cables..
going to move the motor controller into the same cabinet as the controller and drivers are.
Attachment 242012
when i get the machine up and running i am going to make a face plate for the front to tidy it up a bit.
i am also contemplating to incorporate a column brace into the design before epoxying up the table.
incorporating a plate underneath the machine and a couple of steel pillars on the side, parallel to the column for added stiffness
just got my 3 steppers..
soon i have my power supply and then i can start testing the motors and begin building the control cabinet
Attachment 242608
well i got some work done, started painting the enclosure in a machine gray color.. i think it looks nice. =)
Attachment 242714
Attachment 242712
(i don't know why the picture is on its side, on my computer it is the right way around)
Using nothing but the best, biltema! :P cheap but good.
Attachment 242716
when i finish everything i plan on making some large windows out of 6 mm Plexiglas in both doors and on the side..
anyone have experience with using that? i don't know how well it will stand up to the chips and coolant..
next is making doors and a slanting table under the mill.
Good work!
thanks gozos.
i now see the cost and time is way more then anticipated, but it is fun
