586,471 active members*
3,622 visitors online*
    May 2014
    21
    Fiber laser marking machine works
    Attachment 239728
    Three important part of the laser cutting machine processing system
    Laser cutting machine processing system includes three parts laser cutting machines, optical systems and processing machines.
    Laser cutting machine laser cutting machine is the center of the entire processing system, the main role is to create a laser cutting machine laser cutting machine many types, but the principle of laser cutting machines to produce basically the same. Most of the excitation system consists of three parts and laser cutting machine material of the optical resonator. Incentive system is to produce devices of optical, electrical or chemical energy. Incentives currently in use, mainly bright light, electricity or chemical reactions. Laser cutting machine is capable of generating a laser material cutting machine materials such as ruby, glass, beryllium, neon, carbon dioxide, semiconductor, and organic dyes. Control of the optical resonance effect is used to enhance the brightness of the output laser cutting machine, adjust and selected wavelength and direction of the laser cutting machine and so on,the prospect of laser cutters for sale is very good.
    Optical system
    Laser cutting machine output laser cutter beam is subject to the optical transmission system and processed to meet different processing requirements. Optical system comprises a beam linear transmission channel, the light beam refraction portion, focus or scatter system. Linear transmission channel main mirror and fiber optic transmission. currently using optical fiber transmission is mainly ultraviolet light in the near infrared wave to wave range, this transmission is both convenient and secure. But most of the optical system or the use of mirrors, this approach is in the transmission of high-energy laser cutting machine, laser cutting machine must be shielded, otherwise it will be dangerous,the prospect of laser cutting machine for sale is very good.
    Some laser cutting machining process (such as cutting, welding, drilling, cutting, etc.) required to focus the laser beam cutting machine to obtain a high power density; laser cutting and other machining processes (such as heat treatment, coating, alloy, etc.) require a shift of the light within a specific shape with a uniform energy distribution, to obtain a large and uniform surface processing in the low-power system as in the use of the focusing lens or scattering of use, but in high power systems , then the multi-metal reflection, refraction system to avoid thermal lensing. Some laser beam cutting machining process using the mobile processing methods to make the laser beam cutting machine can be controlled to move the optical path system of the mechanical transmission part also added.
    Machining
    Machining a workpiece carrier and to the workpiece and the laser beam cutting machine for movement relative to the processing machine, machining accuracy depends largely on the accuracy of machining and laser beam cutting machine to adjust the accuracy of the movement. Regulation and the trajectory of the beam motion processing machine are controlled by CNC system. Processing machine CNC system needs a good and reliable testing, feedback system, in order to produce accurate product. Many forms processing machines, even can be used with other techniques, such as with robotics, to create a laser cutting machine processing machinery person; or with five-axis machine tools, to create a five-axis machining laser cutting machine laser cutting machine greatly increase the likelihood of processing,the prospect of laser cutter machine for sale is very good.
    May 2014
    Re: Fiber laser marking machine works
    This is a great device! I found some more information on this website: DirectIndustry - The Virtual Industrial Exhibition
  1. Fiber laser marking machine works
    By mornlaser2014 in forum News Announcements
    Last Post: 06-12-2014, 09:11 AM
  2. Replies: 0
    Last Post: 06-14-2013, 08:53 AM
  3. portable fiber laser marking machine
    By hanzlaser in forum News Announcements
    Last Post: 03-08-2013, 10:03 AM
  4. good fiber laser marking machine
    Last Post: 02-23-2013, 07:02 AM
  5. fiber laser marking machine
    By wklaserliu in forum News Announcements
    Last Post: 02-23-2013, 06:55 AM
