OK I have been spoiled with all the large machines that I have ran over the years at work. They all have ATC and its a no brainer . So I got a mill from a user here back in April and it has Mach 3 . I have been reading up and reading up and want to make sure that I am correct here .
in my post I will need to have a G43 h# like any other post correct ? Also make sure that I have the Z high enough to clear the work piece. I think that's all figured out . now to the part I have the main issue with Mach 3.
I am so used to just picking up my Z height and calling out the Z for the job on the big machines . is this the same in Mach 3 ?
call out tool number pick up the cutter off of a 1-2-3 block with the correct Z in the gage block entered in . and so on with each cutter from there on in the correct tool number of course .
now as far as the tool table. Do I need to get a tool # 1 length ? this is the part I do not understand ??
