586,414 active members*
3,119 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Wich cad/cam should we try or use
Results 1 to 7 of 7
    Oct 2006
    10
    With the upgrade from xp to win7 our cad/cam won't work anymore so we are looking for something new. All our drawings are made With Autocad and are then importen to the cam software. Now i've seen Some packages like Autocad/router cim, alphacamexpress or rhinocam. What would be a good package? We only use it for 3axis milling, but we do have a heidenhann scanner on the machine that we also like to use. This is how it works, we scan a surface from point a to b and than we Mill the line on the hight the scanner has detected. Our surface hasn't got a flat plane. The z plane has got his UPS and downs. Any ideas from anybody
    Jan 2007
    1795
    Re: Wich cad/cam should we try or use
    check rhino and visualmill combination..
    it also pending how much you plan to invest..
    Oct 2006
    10
    I guess Max 5000$
    Jan 2007
    1795
    check mecsoft, someone told me rhino or visualmill has capability to creating surface of scanned data, of xyz file..
    accutrans by micromouse also has some converter for.. scanned data to surface..
    Oct 2006
    10
    Is there cad/cam software where the cad side looks familiar with autocad?
    Apr 2004
    5741
    Rhino is a lot like autocad; you can pick icons or enter commands in writing. RhinoCAM is a version of VisualMill (the program people have been telling you about here) which plugs into it. See my site for more information on the various versions which are available.
    Andrew Werby
    Website
    Oct 2006
    10
    I will take a few pictures and video's monday and post them. Then you will see what i mean. I draw With autocad 8 years and work very fast With it. I have 2 separate cam softwares 1 for our CMS milling machine with an Osai post (Wintools by DDX.it) and For our esab waterjet (Columbus by ESAB). Programs for our Reichenbacher 5 Axis Mill are made With the post for the CMS and then hand changed for the other Mill, thats wy i want to have one package for everything. We do 90% 2D work.
  1. Wich Cam - Cad/cam
    By 7of9 in forum Chinese Machines
    Last Post: 05-13-2012, 04:03 AM
  2. Wich software to buy?
    By Vladimir_Zg in forum CNC Machining Centers
    Last Post: 11-21-2008, 04:11 PM
  3. Wich spindle is best??
    By quant in forum Uncategorised MetalWorking Machines
    Last Post: 06-23-2007, 04:24 PM
  4. does somebody know, wich software?
    By BL4ST in forum Uncategorised CAM Discussion
    Last Post: 02-15-2007, 03:09 PM
  5. Wich leadscrew? (how much TPI)
    By CnC_BoY in forum DIY CNC Router Table Machines
    Last Post: 03-25-2006, 09:20 PM
