586,129 active members*
2,725 visitors online*
    Sep 2013
    7
    [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    Hi Guys,
    My mate has an old CNC machine which his dad imported from china. I just recently swapped over the old pendant hand controller to a newer model(thanks to RussellK for the guidance). Before I swapped over the controller I turned on the machine on and played around with the movement. The X and Y axis was working fine. The Z axis wasn't working. I didn't look into it and continued with the swap over.
    After I had swapped over the controller the machine was turned on and running, but still the Z axis was not moving.
    I think there maybe a wiring issue somewhere. I'm not sure where to begin.
    Can anyone provide me with any advice on where to start looking for the problem?
    Attachment 238214Attachment 238216Click image for larger version.
ID:	238218Click image for larger version.
ID:	238222Click image for larger version.
    thanks in advance
    Bao
    Jul 2006
    182
    Re: [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    The last pic showing the guts is where you need to look. Some closer, square-on pics of the bits and how they're connected would be a help.
    In short, though, you should be able to swap, say, the X and Z outputs of the interface board (the one on the bottom right, and assuming they're wired the same) and see if moving the X moves the Z. That'd tell you if it's a software config problem or a hardware problem.
    Sep 2013
    7
    Thanks Russ. Ill let you know how I go
    Sent from my GT-I9505 using Tapatalk
  1. 4th axis advice needed
    By WOTDesigns in forum Benchtop Machines
    Last Post: 11-23-2011, 07:09 AM
  2. Advice needed for 6-axis motion control rig
    By DarkStar01 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2010, 03:10 PM
  3. Tool Maker/ injection mold builder needed!
    By MnotLyon in forum Employment Opportunity
    Last Post: 03-08-2007, 08:57 PM
  4. Some advice needed on X-Axis belt issues.
    By kumaichi in forum Charter Oak Automation Support Forum
    Last Post: 02-21-2007, 03:47 PM
  5. Advice Needed Regarding Bridgeport Interact Axis Motors
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2006, 11:45 PM
