I have been retrofitting an old Emco F1 mill. Ewerything is working fine except the spindle speed control. I run Mach3 which controlls the Leadshines Mx3660 controller. I have configured ewerything in mach3 ( the controller needs the pwm signal at pin 14). The controller is connected to the old motor control board of the Emco which previously had a potentiometer wired to it but I replaced that with the analog output of the controller.Attachment 238064Attachment 238066Attachment 238068Attachment 238070
The motor control board (without the potentiometer and the controller) just kept speeding up the spindle until it reached top speed. When I connected the input wire with ground it slowed down. I have no idea what is wrong and why it doesnt work. When I turn on the relay that supplies the control board the spindle starts to turn but it runs on the minimum setting And changing anything in Mach3 doesnt affect anything. So I guess that something is wired wrong?
