586,734 active members*
2,984 visitors online*
    Feb 2007
    19
    Wink sodick A320D EX21 control
    Hi all,
    I am having trouble with my Sodick A320D with EX21 control. On firing up the machine I get an error flashing "H004 DATA FILE IS NOT FOUND IN DRIVE 2, SET THE DISK AND PUSH ENT".
    I reset the disk and remove and insert the floppy in drive 2 and still get the same error. I have inserted a new user disk and still the same error. Can I bypass this error and proceed to fire up machine? has anyone out there seen this before and have a remedy? My sodick service rep is overseas for 2 weeks and I need to get my machine going desperately.
    Any help would be appreciated.
    Thank you.
    Jul 2014
    11
    Re: sodick A320D EX21 control
    We actually had that problem on our Sodick A320L with the Mark EX control. We had to send the computer in for repair. Something about a blown capacitor I believe.
    Mar 2016
    8
    please can you help me,
    i have a problem on my sodick A320D ex21,
    when it is loading it stops on (system loading 12/100) and show red message:
    (SYS2 version up install
    Insert the floppy disk in the USER side ,press the any kay.)
    can you help me pls?
    i need floppy disk 1 and 2 and 3
    May 2017
    Does anyone solved the problem on SYS2 VERSION INSTALL DISK?
    Aug 2020
    9
    Quote Originally Posted by cncmedcom View Post
    Hi all,
    Thank you.
    Did you end up fixing this problem ?
    Apreciate any help
    thanks
    Feb 2022
    Hi how do you reset the disk? i have only on floppy driver, thanks in advance
  1. Needs help !!! Sodick A320D with AWT - Control EX21
    By mescotc in forum EDM Discussion General Topics
    Last Post: 08-22-2023, 06:44 PM
  2. Fine Sodick A320D with EX21 - Flushing pump is oscillating
    By Powerjunky in forum EDM Discussion General Topics
    Last Post: 12-26-2013, 02:23 PM
  3. UG NX4 PostProcessor for Sodick EX21 A320D
    By Chris 1st in forum UG NX
    Last Post: 01-06-2009, 01:22 PM
  4. RS232 connection of Sodick A320D AWT EX21
    By Mouldmaker in forum Uncategorised CAM Discussion
    Last Post: 10-20-2003, 12:36 PM
