586,588 active members*
2,571 visitors online*
Results 1 to 5 of 5
    Dec 2012
    569
    what on earth is this thing
    this came with my mill when I bought it, but I dont think it was actually part of it, it was just laying inside it
    however, it may have something to do with it...although I dont really see how. the mill is a mini mill and this machine thing is bigger than its bed.
    it appears to be two linear actuators, each mounted on two rails, with a screw and motor. the screw may be ball screw.
    then, perpendicular to all that, there are four linear ball bearing bearings which look to allow two larger rails
    as if this were the "X" axis and the Y axis is some larger piece of equipment
    whats weird is the front
    there are two "flags" welded to each linear actuator which come out the front, sort of like position indicators..there is a sticker that says "PHS2" near one
    and there are two circular passages with orings on the front two..dont seem connected to the main mechanism though
    WTF is this???
    Id like to tear it apart for its goodies but Id hate to do that if its actually part of some machine someone needs...it looks a little shop-made though..not so much part of a commercial machine
    any ideas?!?!?!!?!?!
    Dec 2003
    24223
    Re: what on earth is this thing
    Not a clue, but I am guessing that it was for some unique or dedicated purpose that was custom made for manufacturing a certain contract project
    Al.
    Albert E.
    Dec 2012
    569
    Al.
    it does look that way
    one more reason to tear it apart for parts..ill just see if anyone else chimes in and then its a dead man
    Oct 2013
    57
    Probably was used in an assembly process .... I see slots that more than likely once held limit switches
    Jun 2010
    4256
    You bought your mill second hand from someone?
    Then just maybe it is an abandoned project to make some sort of XY table for a future machine ... but the maker gave up.
    Well, maybe.
    Cheers
  1. Earth Sheltered or Earth Bermed homes
    By Edwardo in forum Environmental / Alternate Energy
    Last Post: 07-12-2012, 11:01 AM
  2. How on earth can this be done??
    By SwampDonkey in forum MetalWork Discussion
    Last Post: 01-12-2012, 11:31 PM
  3. Why on earth does emc not start?
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 07-11-2011, 04:05 AM
  4. How on earth do you cut THK LM rail?
    By jimmyaz in forum DIY CNC Router Table Machines
    Last Post: 05-14-2011, 02:30 PM
  5. Earth Ground
    By LYN BYRD in forum Milltronics
    Last Post: 06-20-2007, 05:39 PM
