586,395 active members*
2,926 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Z axis alphacam - Xilog plus
    May 2014
    Hello.
    I just buy a MORBIDELLI author 600kxl that goes with the XiLog plus.
    however'm also trying to work with alphacam 2013 r1 as I have to record some logos that I have in dxf.
    however, once I get to do the machining (more or less) to open it in the XiLog me appear as if I was watching the board from below, ie, all letters as if in a mirror.
    not know if I've explained well ... Maybe it's an issue of the origin coordinate, since I "zipcode cn for each panel uses bottom left point x0 y0" appears Although then I've been moving the origin of the work table for all the sites out well. any ideas?
    I put a couple of photos for you to see my problem.
    Thank you in advance.
    Attachment 237644Attachment 237646
    Re: Z axis alphacam - Xilog plus
    The origin of the Morbidelli and Xilog is back left, so I think your Alphacam post needs to flip the coordinates.
    May 2014
    Thank you very much for your quickly.
    How I can change the coordinates of Alphacam?
    I tried to change the coordinate origin in the plane of work but in the end I always get upside down.
    I don't think you can in AlphaCAM. You need to do it in the post processor. I don't know how it's done, as we got out post that does this from SCM.
    Everything I do in AlphaCAM has the origin at the bottom left, but when the code is output, the post "flips" it.
    May 2014
    Quiet. I will keep investigating.
    Thanks for everything.
    Dec 2008
    10
    You could mirror the entire job after creating and out put that which would be mirrored on the machine to cut correctly.
    Steve Searle, Alphacam Training Manager Alphacam 2014 R2
    Vero Global Support Portal http://customers.verosoftware.com/
  1. Post processor Alphacam 4 axis
    By jona in forum Alphacam
    Last Post: 11-04-2020, 10:39 AM
  2. configuring Alphacam postprocessor for 5 axis mill
    By bimbi.tmp in forum Uncategorised CAM Discussion
    Last Post: 03-28-2013, 12:15 PM
  3. 5 axis router (carolinas) alphacam
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 07-26-2011, 06:23 PM
  4. Alphacam to xilog (Routolink).Tool length problem
    By alanhende in forum Controller & Computer Solutions
    Last Post: 05-27-2010, 10:12 PM
