586,570 active members*
3,699 visitors online*
IndustryArena Forum > CAM Software > OneCNC > One cnc post for C Tek / CNT controller
Results 1 to 12 of 12
    Dec 2007
    8
    I am looking for a post for the above controller. C Tek also know as a CNT Controller The machine goes under the brand name guise of 'powercentre' in the UK, all be it an optimistic name I have no idea if this machine/ controller is marketed in the USA or other countries. I guess it must be as they have to be sold somewhere.
    I have already posted in the onecnc forum but that's a little used forum with not a lot of exposure it seems.
    I have attached an image of the control if case it rings any bells with someone seeing this controller used with onecnc
    Any information or even a post to try would be appreciated.
    Kind regards,
    Attachment 237546
    Re: One cnc post for C Tek / CNT controller
    Hi Scott
    Here is the post for your c-tek controller
    just unzip and put in your settings folder where OneCNC is installed on your pc
    Attachment 281616
    Mar 2016
    THANK YOU f
    Nov 2010
    Hi ,
    Can anyone help out with the post processor for the same CTek machine as above but running bobcat V21 ??
    Oct 2018
    7
    Quote Originally Posted by k99arl View Post
    Hi ,
    hi i have same controller on rambo v5 can you offer any help or advice im in uk winsford cheshire were machine based thanks my no 07830179584
    Hey guys thanks for the file for One CNC and Ctek.
    Ours has the same control as pictured.
    I've tried to load a program from onecnc into the machine via floppy disk and having no luck at all.
    There's not much out these about these machines. Any help greatly appreciated
    Matt
    Sep 2021
    BUENAS NOCHES, AL MOMENTO DE INTALALR EN MASTER CAM NO ME DEJA ACCEDER
    Quote Originally Posted by Kinger8938 View Post
    Matt
    Hi Matt,
    My employments workshop has this type machine, and have been battling as well. Ours doesn’t have a floppy but I’ve seen the Rs-232 cable work to a usb and laptop. I’ve been programming manually in the meantime. I’ll keep you posted with progress… does anyone know what file type C-Tek/ CNT accepts?
    Quote Originally Posted by RichyRich View Post
    Hi Matt,
    Hi richyrich
    Im programming with solidworks solid cam and i need to save the file as .cnc for it to accept it
    I am also battling to get the right post processor to communicate properly with the machine as some of my programs dont want to work on machine but it does on the simulation
    May 2022
    4
    I have the identical CTek machine described above, but I'm using Bobcat V21, and I need some assistance with the post processor.
    the backrooms
    Feb 2023
    Hello. Does anyone have information about controlling the milling machine with c-tek control.
  1. post for DSP controller
    By Joa in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-29-2012, 07:09 PM
  2. post processors for DSP controller
    By Joa in forum Chinese Machines
    Last Post: 03-29-2012, 05:02 PM
  3. DX-32 controller post
    By Cellar Dweller in forum Post Processors for MC
    Last Post: 01-06-2011, 07:24 AM
  4. post for t-2 controller
    By tward74 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2010, 08:45 AM
  5. Need post for Fanuc 0MC Controller
    By Bruce Griffing in forum Dolphin CAD/CAM
    Last Post: 09-18-2009, 09:55 AM
