586,216 active members*
3,090 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Machining time no longer displayed in V26 simulation
Results 1 to 11 of 11
    Jun 2013
    15
    Hello,
    I have just upgraded from V25 to V26.
    In the simulation window, when in "time-based mode", V25 was showing the machining time in upper right corner (see screenshot below).
    In V26, this information is no longer displayed.
    Any clue ?
    Thanks.
    Frederic.
    Attachment 237436
    Jun 2008
    1838
    Re: Machining time no longer displayed in V26 simulation
    Quote Originally Posted by f1oat View Post
    Hello,
    Any clue ?
    Thanks.
    Frederic.
    Attachment 237436
    I think it may be because it really isn`t needed anymore since the setup sheets became available, it is now easier to just generate a setup sheet which has all the run times for every operation (In Full Setup sheet) without needing to run the simulation at all
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jun 2013
    15
    Rob, thank you.
    Yes, setup sheet is quite comprehensive and gives the machining time.
    I can also see it in the statistics tab.
    The only missing information is the progress during simulation expressed in time.
    But that is not a big issue as the progress bar in the bottom gives a visual estimation.
    Frederic.
    Jun 2012
    514
    Thumbs up Re: Machining time no longer displayed in V26 simulation
    it should show it..period..not everyone prints the damn sheet out....but we do look at the machine time when simulating to improve it...so i can change tool paths or strategies...BRING IT BACK!!!!!!!! ANOTHER REASON WHY NOT TO UPGRADE!
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Aug 2012
    621
    Machining time per operation and overall is shown in the Statistics tab of the simulation. It isn't a "real-time" countdown, but it still ought to be helpful.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Jun 2008
    1838
    Quote Originally Posted by Big Chips View Post
    Not any need to "print the damn thing out", just a couple of clicks and it`s easy to check times without even running the simulation and as "trotline" points out the times are there in the sim as well.
    I am checking the setup sheet facility as I go with almost every Feature I do, just so easy to do a quick check and change whatever is needed without running the sim, saves loads of time
    Regards
    Rob
    Apr 2008
    1577
    Not my biggest gripe by any means as there are numerous tools to do the same task already mentioned (including Predator which is always *Spot On*) but I would prefer to have it back. First World Problems, right?
    Apr 2009
    3376
    I would like to see it back also,,for the record..
    Sep 2012
    1195
    If they were to improve anything to do with the run time in simulation, I'd first like to see the simulation take accel/decel into account so the estimated time is more meaningful. In most cases it's only showing about half of the real world run time (my machine runs at 200-800 ipm often, so accel/decel is a huge factor). I don't really have any problem looking in the statistics tab for the time estimate, but you do have to scroll down to see the overall run time (I can only see the current operation run time without scrolling). It would be nice to see it on the screen as the OP showed in V25.
    Jun 2012
    514
    simple things like this..can cost thousands in sales....SMH !!!!!!! Hope it shows back up in v27....
    Apr 2009
    3376
    We be missing your "Banana's too
    :banana::banana::banana:
  1. Simulation Control Panel not displayed
    By mike256 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-26-2017, 04:29 PM
  2. Machining time in V9
    By sblack in forum Mastercam
    Last Post: 07-31-2013, 08:50 AM
  3. cycle time from simulation
    By bigbobr in forum Mastercam
    Last Post: 04-27-2012, 10:33 PM
  4. Use cycle simulation time error
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-14-2011, 07:53 AM
  5. Longer parallel cable or longer steper wires?
    By jvanick in forum Hobbycnc (Products)
    Last Post: 09-13-2008, 11:51 AM
