587,006 active members*
2,878 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Need a little help tweaking my lathe mpost
Results 1 to 20 of 21
    May 2014
    9
    Hello everyone!
    Long time lurker first time poster. I have been using Surfcam for about 6 years now. The posts my company used were never truly correct and they always hand edited them. I've taken it on my self to fix this once and for all. I've managed to edit several posts successfully but one is still throwing me for a loop. What i'm looking for is the structure format Mpost uses. I now all the command, sequences and variables. I just dont understand the structure it decides to output code.
    For example:
    here is my Mori post form:
    name MORI LATHE
    % 00
    O 4
    N >3
    G >2
    X ->3.>4
    Z ->3.>4
    D >2
    I ->3.>4
    K ->3.>4
    p >4 P
    q >4 Q
    d ->3.>4
    U ->3.>4
    W ->3.>4
    P ->3.>4
    Q ->3.>4
    R ->3.>4
    F >3.>3
    A 2
    T >2
    S >4
    M >2
    u 2
    ModalLetters X Z I K F S M
    ModalGs 0 1 2 3 80 81 82 83 84 85
    Sequence#s N 0 1 10 10 100
    First#? N
    Last#? N
    HCode Z
    VCode X
    FeedCode F
    Comment ( )
    Spindle 3 4 5
    Coolant 8 9 7
    SpeedType G 97 96
    Dcomp 41 42 40
    Feed G1
    Rapid G0
    Cw G2
    Ccw G3
    Sbackdoor Supressheader
    Inc/Abs G 91 90
    Inch/MM 20 21
    CtrCode R
    Leading0s? N
    ByDiameter? Y
    RevSigns
    Spaces? Y
    Incremental? N
    CtrIncremental? Y
    ByQuadrants? Y
    ReturnPlane 98 99
    UppercaseComments? Y
    Tap
    G77 Z[H] K[Vclear] F[FRate]
    End
    Ream
    G74 Z[H] K[Vclear] F[FRate]
    End
    Bore
    End
    AutoThread
    G33 X[V] Z[H] F[Frate]
    End
    Rough
    if [TipAng] = -90
    G72 p[StartN] q[EndN] d[Step] U[VLeave] W[SLeave] F[plunge]
    else
    G71 p[StartN] q[EndN] d[Step] U[VLeave] W[SLeave] F[Plunge]
    endif
    End
    Finish
    G70 p[StartN] q[EndN]
    End
    Cancel
    G80
    End
    Upon [Speed]
    M[Direct] S[Speed]
    End
    StartCode
    %0
    O0
    End
    1stToolChange
    G18
    "G0 G28 V0."
    "G0 G53 X0. Z-15."
    G50 G99 S[MaxRpm]
    G[Work]
    G0 T[Tool]
    G[Work] G99 G18
    M69
    M46
    G[SpeedType] S[Speed] M[Direct]
    G0 X[V] Z.1 M[COOL]
    Z[H]
    End
    Infeed
    G0 X[V]
    G1 G[Side] Z[H] F[FRate]
    End
    Outfeed
    G1 X[V]
    G1 G40 Z[H] F[FRate]
    End
    ToolChange
    G0 Z.3 M[coolantoff]
    "G28 V0."
    "G53 X0. Z-15."
    M5
    M01
    G0 T[tool]
    G[Work] G99 G18
    M69
    M46
    G0 X[V] Z.1 M[COOL]
    End
    EndCode
    "G28 V0."
    "G53 X0. Z-15."
    M5
    M30
    %0
    End
    Replace "C0" with "C0."
    Replace "T1" with "T0101"
    Replace "T2" with "T202"
    Replace "T3" with "T303"
    Replace "T4" with "T404"
    Replace "T5" with "T505"
    Replace "T6" with "T606"
    Replace "T7" with "T707"
    Replace "T8" with "T808"
    Replace "T9" with "T909"
    Replace "T10" with "T1010"
    To me it looks like my postform is correct but the output is still not correct.
    Below is a very basic turning canned cycle operation:
    O0000
    G18
    G0 G28 V0.
    G0 G53 X0. Z-15.
    G50 G99 S3000
    G54
    G0 T01010
    G54 G99 G18
    M69
    M46
    G96 S600 M3
    G0 X1.2532 Z.1 M8
    Z.0131
    G0 X1.0674 (what controls this line)
    G71 P100 Q110 D.1 U.01 W.003 F.012
    N100 G0 X0
    G1 G42 Z0 F.006
    G1 X.35
    G3 X.45 Z-.05 R.05
    G1 Z-.2451
    G2 X.55 Z-.2951 R.05
    G1 X.6826
    G3 X.7826 Z-.3451 R.05
    G1 Z-.4886
    G2 X.8826 Z-.5386 R.05
    G1 X.9
    G3 X1. Z-.5886 R.05
    G1 Z-1.
    X1.25
    N110
    G0 X1.0674
    Z.0131 (where does this come from)
    G70 P100 (missing the Q110)
    G1 X1.25
    G40 Z-.9984 F.006 (This looks like my Outfeed sequence, but why is it way down here?
    G0 Z.3 M9
    G28 V0.
    G53 X0. Z-15.
    M5
    M30
    I can't figure out where the phantom lines of code are coming from and how to change it. I'm hoping someone here can help me.
    -Nick
    May 2014
    9
    Re: Surfcam Mpost help
    I also just noticed that my tool numbers aren't coming out correct either....
    T010101 should be T1010
    T[tool] should be outputing T10 which would be replaced with T1010 right?
    May 2014
    9
    Re: Need a little help tweaking my lathe mpost
    Nevermind I think I figured it out. I found out how to have surfcam post the LOG file. It shows you all the CL data and what it coverted it too. I should be able to figure this out.
    May 2013
    142
    You could shorten those replace commands by adding t >2 to your letter addresses, then change your tool change line to T[Tool] t[Tool] , after that you only need 1 replace line Replace " t" with "" . This also wouldn't hard code limit you to 10 tools.
    May 2014
    9
    Quote Originally Posted by Billetgrip View Post
    Awesome! thats one fix down, thank you.
    Now about my other problems. here are the lines in question:
    O0000
    G18
    G0 G28 V0.
    G0 G53 X0. Z-15.
    G50 G99 S3000
    G54
    G0 T1010
    G54 G99 G18
    M69
    M46
    G96 S600 M3
    G0 X1.45 Z.1 M8
    G0 X1.47
    X1.4732 Z.0131
    X1.0674
    N100 G0 X0
    G1 G42 Z0 F.006
    G1 X.35
    ..... etc
    Here is the same lines from the .log file:
    ---INC Type 0, 12 bytes. (Rapid) 0.1 0.735 0. #12.
    12 TM:>position< 0.1 0.735 0. 12. ""
    G0 X1.47
    ---INC Type 0, 12 bytes. (Rapid) 0.0131 0.73656 0. #13.
    13 TM:>position< 0.0131 0.7366 0. 13. ""
    X1.4732 Z.0131
    ---INC Type 0, 12 bytes. (Rapid) 0.0131 0.53366 0. #14.
    14 TM:>position< 0.0131 0.5337 0. 14. ""
    X1.0674
    What sequence controls these moves so that I can either edit them or remove them entirely?
    May 2013
    142
    They may be lead-in/ initial rapid/ clearance plane moves that mpost is trying to correct from the hard coded moves before it.
    Example copied from your post above:
    G0 X[V] Z.1 M[COOL]
    Z[H]
    End
    What is the purpose of the bolded part? Why not let surfcam take care of it?
    May 2014
    9
    G0 X[V] Z.1 M[COOL]
    Z[H]
    End
    My bad I should have included the changes I made.
    here is the full beginging of the .log file:
    ---OUTPUTTING SEQUENCE: STARTCODE---v
    Template: >> %0
    Template: >> O0
    O0000
    ---FINISHED SEQUENCE STARTCODE---^
    ---INC Type 231, 460 bytes. (Header) 302 (Discarding 90 bytes.)
    ---INC Type 221, 190 bytes. (Text [221])
    ---INC Type 244, 80 bytes.
    ---INC Type 243, 4 bytes. 243: UNRECOGNIZED (Discarding 4 bytes.) #4.
    1 TM:>unknown< 243. 4. 0. 4. ""
    ---INC Type 208, 128 bytes. (View) (Discarding 30 bytes.) 1 1. 0. 0. 0. 1. 0. 0. 0. 1. 0. 0. 0.
    ---INC Type 203, 0 bytes. (Multi On [202] or Off [203])
    ---INC Type 10, 176 bytes. (Ext. cutter info) 2 (Discarding 48 bytes.) 0 (Discarding 4 bytes.) 1 (Discarding 4 bytes.) (Discarding 12 bytes.) 0.01563 0.55 (Discarding 8 bytes.) (Discarding 8 bytes.) (Discarding 16 bytes.) (Discarding 48 bytes.) #7.
    2 TM:>style< 0.55 1. -1. 7. ""
    ---INC Type 199, 196 bytes. (Ext. TC) (Discarding 44 bytes.) 0 0 0 0 10 10 10 0 1 600 1 1 1 (Discarding 4 bytes.) 0 0 0 0. 0. (Discarding 8 bytes.) (Discarding 36 bytes.) 0. (Discarding 20 bytes.) #0.
    3 TM:>fluid< 1. 0. 0. 0. ""
    4 TM:>speed< 600. 1. 0. 0. ""
    5 TM:>style< 0.55 1. 0. 0. ""
    6 TM:>turret< 1. 0. 0. 0. ""
    7 TM:>number< 10. 10. 10. 0. ""
    8 TM:>unitmode< 0. 0. 0. 8. ""
    ---INC Type 204, 4 bytes. (Feed rate) 0.006 #9.
    9 TM:>frate< 0.006 0.012 0. 9. ""
    ---INC Type 205, 4 bytes. (Plunge rate) 0.012 #10.
    10 TM:>frate< 0.006 0.012 0. 10. ""
    ---INC Type 0, 12 bytes. (Rapid) 0.1 0.725 0. #11.
    11 TM:>position< 0.1 0.725 0. 11. ""
    ---OUTPUTTING SEQUENCE: 1STTOOLCHANGE---v
    Template: >> G18
    G18
    Template: >> "G0 G28 V0."
    G0 G28 V0.
    Template: >> "G0 G53 X0. Z-15."
    G0 G53 X0. Z-15.
    Template: >> G50 G99 S[MaxRpm]
    G50 G99 S3000
    Template: >> G[Work]
    G54
    Template: >> G0 T[Tool] t[tool]
    REPLACING " t" with ""
    G0 T1010
    Template: >> G[Work] G99 G18
    G54 G99 G18
    Template: >> M69
    M69
    Template: >> M46
    M46
    Template: >> G[SpeedType] S[Speed] M[Direct]
    G96 S600 M3
    Template: >> G0 X[V] Z[H] M[COOL]
    G0 X1.45 Z.1 M8
    ---FINISHED SEQUENCE 1STTOOLCHANGE---^
    from my postform:
    1stToolChange # First tool change
    G18
    "G0 G28 V0."
    "G0 G53 X0. Z-15."
    G50 G99 S[MaxRpm]
    G[Work]
    G0 T[Tool] t[tool]
    G[Work] G99 G18
    M69
    M46
    End
    As you can see I changed it to allow surfcam to go to clearence point.
    G0 X1.47
    X1.4732 Z.0131
    X1.0674
    (the above is still a mystery move to me.)
    May 2013
    142
    Hmm got me...that seems to be the issue with any of the "turning" canned cycles. My threading cycle inserts a pointless line before and after the G76 line. I never use the G70/G71/G72 cycles so I can't really comment on them. If you can stand the slightly longer program try unchecking the "Enable Canned cycle" box and see if that gets you what you want.
    May 2014
    9
    That will post fine. However I like using the canned cycles. It makes it a lot easier to change by hand if needed. As of now I usually just post a finish path and copy and paste it into my blank prgram template. its works fine but it would be awesome if I could post directly from surfcam
    May 2013
    142
    I told you the tool change thing wrong. Replace the "t >2" with "t 2". With the way it is now it will post T44 for tool 4. The fix will post T404. My bad.
    May 2014
    9
    yeah I fixed it already
    all good
    Mar 2008
    45
    Can you show how to make Surfcam post the log file? Thanks!
    May 2013
    142
    Logging? Y command in the post.ini file or take the logging command completely out. That's how the manual says to do it. Never worked for me though.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    May 2014
    9
    Quote Originally Posted by marine1775 View Post
    No problem.
    Go to your surfcam directory and find the Mpost folder
    ex: C:\Program Files\SURFCAM\V5_2\MPost
    look for the post.ini file
    open it in notepad
    add this line under whatever postform you want to log
    Logging? Y
    ex:
    [MPOST]
    Format C:\Program Files\SURFCAM\POSTLIB\PostForm.m
    Logging? Y
    [LPOST]
    Format C:\Program Files\SURFCAM\POSTLIB\PostForm.l
    Logging? Y
    [EPOST]
    Format C:\Program Files\SURFCAM\POSTLIB\PostForm.e
    Logging? Y
    This will create a log file in the Mpost folder everytime you post. it may slow processing down if you have a large file, its more for debugging. it rewrites everytime.
    May 2013
    142
    For anything newer than v5.2 the path is C:\Program Files\SURFCAM\your version of surfcam\Apps\MPost
    Mar 2008
    45
    Thanks. Only problem I am having now is it will not let me save the file. I get access denied
    May 2014
    9
    right click on the .ini file > properties and uncheck the box that says read only. hit apply and you should be good to go.
    Mar 2008
    45
    I got it to save but I may be having the same problem Billetgrip is having. I run my post after changing the post.ini file and there is no .log file in the mpost folder. Any thoughts?
    Obviously you're running Surfcam V6, and from there on Surfcam has changed the file structure; the info to find it is located in page #4 on the Whats New file;
    Mario
    May 2013
    142
    Quote Originally Posted by mariojl View Post
    Mario
    Using 2014 R2 on a Win 8.1 comp. The location of the .ini file isn't the problem. It just simply doesn't work like the manual says.
  1. Modify MPOST siemens840 de
    By sinan-ba in forum Surfcam
    Last Post: 02-25-2014, 01:36 AM
  2. need help with mits fx 20 wire edm mpost
    By marine1775 in forum Surfcam
    Last Post: 02-03-2014, 07:38 PM
  3. Spost vs Mpost
    By forjaco in forum Surfcam
    Last Post: 03-22-2013, 09:09 AM
  4. Surfcam Hole Cycle Types and Mpost
    By Fest911 in forum Surfcam
    Last Post: 11-30-2012, 09:08 AM
  5. Hurco & SurfCam Mpost????
    By lkenney in forum HURCO
    Last Post: 10-05-2011, 06:04 PM
