586,110 active members*
3,273 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Xylotex 425 motors with gecko G540?
    Apr 2009
    35
    I have a xylotex box and motors and am planning to upgrade to a gecko 540. Can I use the 425 oz motors with the gecko?
    StuartC
    https://www.stuartgraphics.com/
    210
    Re: Xylotex 425 motors with gecko G540?
    My smaller ones work fine
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    May 2005
    1662
    Quote Originally Posted by StuartC View Post
    I'm using that motor with the G540 on my X2 mini-mill z axis.
    It's not the ideal choice (high inductance ?) but it works no problem.
    Feb 2009
    192
    If you are using high pitch lead screws (15 to 20 tpi) then the 269s would be the recommended choice. If you are using lower pitch screws, like 5 tpi ball screws, then the 425s would be the better choice.
  1. Best PLace to Buy Gecko G540 w/ 3 Nema 23 motors?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 11-23-2012, 08:34 PM
  2. 2 Motors 1 Axis Driver in Gecko G540
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 06-10-2012, 04:00 AM
  3. mach 3 won't run motors w/ Gecko g540
    By Super Coffee in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 07:37 PM
  4. Config for 2 motors on x-axis (w/ Gecko g540)
    By rogerer in forum LinuxCNC (formerly EMC2)
    Last Post: 05-17-2009, 03:30 AM
  5. Gecko G540 from Xylotex
    By gadman58 in forum Gecko Drives
    Last Post: 01-19-2009, 07:37 AM
