Hi all,
Just putting the finishing touches to the 1100 list i hope to order in the next couple of weeks but would like some advice on the following... I did try and search previous posts about this stuff but didn't find exactly what i was looking for.
1 Vise - I would like the ability to mount the vise on its side so that rules out things like the D688, Tormachs 5" machinists etc, which leaves me with a couple of options and I'm leaning towards the GPV615
Glacern GPV-615 looks a good vise, great feedback on it but I'm a little worried about a potential loss in the Y-Axis envelope
Tormach 5" CNC well suited to the Machine... i just really don't like the rear jaw not being a solid part of the vice body.. repeatability issues? Also small Max opening
Kurt 3600v Expensive and maybe a little long? I haven't seen many people using these with this mill
2 Machine Arm - Do many people bother with this option? I'm thinking it might be better to sit the Monitor and keyboard and a separate desk or bench beside the machine
3 4th Axis - I think I've decided that the 6" Fixed will do for most stuff i think i will ever make. I'm not going for an ATC right now but i might want that option in the future which will probably
be happier with the 6" option. Am i being foolish in not going for an 8" table? Also the tilting tables look like they will eat too much of the main table space up to be a good option. Any advise would be welcome.
4 Air turbine Spindle - This is the interesting one. I will be using some very small KT carbide cutters down to about 12 thou. I have decided that the 602xjs Spindle from Air Turbine Tools at 50k will be
the best fit for what i need. I emailed both companies about this and got zero response from ATT and a sort of admission that Tormach were looking into this sort of solution but
no real "help". The official line was its a 3rd part addition so they couldn't comment. I see it as just another piece of live tooling. I would really appreciate hearing from anyone who
has tried this setup? At the moment It comes with a 3/4 x 2" straight shank so it would need a regular R8 collet rather than TTS. Having said that, the side loading would be so
small, i can't see a problem with shortening the shank down and fitting a TTS adapter kit to it.... I'm guessing no ones done this yet? Im a bit reluctant to start cutting up a $3000
spindle!
5 Tool setter - I haven't found any information on Tormachs ETS for minimum Tool diameter, just 480g trigger force. Im thinking that will be a little high for some of the small cutters i want to use. The Blum Pico-Z looks like the right fit but i found no information on prices so I'm guessing its way too much for me to afford and probably overkill. Hexagon Metrology also sell one for about $1300 and spec says down to 0.1mm and a trigger force of 2.2N. Thats 220g of force for a 0.1mm cutter... extrapolating out, maybe the Tormach ETS would work on a 0.3mm cutter???
The other option is to not bother with an electronic tool setter and set it using a height gauge off the machine, but that means i would have to convert the Air spindle to TTS and cut it down for repeatable loading in Z. Any other ideas that or advice would again be welcome.
6 3"shell Mill - I already have an Iscar HOF D3.00-5-1.00-R07 and a bunch of inserts on an R8 arbor. I'd like to reuse it if i can but I'm worried it might be asking too much of the Tormach in terms for spindle power and rigidity. I have seen that its possible to buy a 1" x 3/4 straight shank arbor from shars and cut it down to fit the TTS. Would it be possible to use with light cuts or would it be better to sell it and get the superfly instead? Again, any advice would be welcome.
thanks in advance for any help guys!
