First, let me thank everyone for their contributions. I have been lurking a few weeks and am still amazed and the depth of knowledge shared on the site.
I am a residential contractor of sorts and have been contemplating a CNC wood router build that will be used primarily for sheet goods. Mostly .75" melamine and plywood. (Cabinets, closets, etc.) As such I need to be able to have a y-axis working envelope 60" or greater to accommodate both 5 x 5 and 4 x 8 stock. While I don't expect to replicate an Onsrud, this is not a hobby machine. It may only run a few hours a week, but it needs to be capable of processing a decent number of sheets daily if need be. (30ish, maybe 40??) Based on my research thus far I have the following requirements: (Which are probably all wrong!)
1.) It must be able to consistently and accurately make clean cuts in a nested routing application. (more on this later)
2.) Vacuum hold down system
3.) Pneumatic pins for positioning
4.) Air drill for boring as I anticipate having a single spindle w/o ATC capabilities
5.) AORN I am planning on a 3kw chinese spindle (water cooled?) with a good VFD (Hitachi?)
6.) My understanding is cutting speed affects tool life and it certainly affects the bottom line, so I want something that can cut decently fast and clean.
7.) Budget: Under 10k is the goal, but I have an additional 5k in the budget. (That I would rather not spend!)
As for my skills they are as follows: I have zero hands on CNC experience. My fabrication abilities are OK, but I have some friends who are very capable and I am not afraid to pay someone to do something I am not capable of. Anything beyond installing a ceiling fan or light switch is uncharted territory for me, so I will definitely need the Wiring for Dummies manual on this project! While I don't have any specific relevant software experience, I am not worried about learning whatever software is necessary.
I have done a fair amount of research on the Mechmate builds, as well as CNCRouterparts builds, and read the entire Widgetmaster Big Red thread. (And the MadVac build as well) Due to my inexperience I am leaning towards a known design, preferably one with several active users.
As such, the obvious candidates (to me!) are the Mechmate and CNCRouterparts builds. I have concerns about cut quality on the Mechmate (fuzzy edges on MDF) and I have concerns about the rigidity of an 8020 build (for my purposes). Also, the CNCRP kits are a maximum 4x8, so I was thinking more of adopting the linear motion, motors, electronics, etc. of a CNCRP to a steel frame.
So other than asking what should I build? I have three specific questions:
1.) Does anyone have experience with the Mechmate specifically wrt sheet goods for cabinets? If so, what kind of feed rate and cut quality are you experiencing? (I realize that build quality of MM differ, thus leading to differing outcomes, but I am curious if anyone has hands on experience with one. I plan on posting on the MM forum as well)
a.) Are some of the issues with MM cut quality (that I could totally have misinterpreted btw) due to direct drive? I see some people have geared their MM and the quality seems good to me, but I am curious about consistency with nested routing.
2.) Is my conclusion that steel, as opposed to 8020, will be better suited for my application correct?
3.) What kind of precision and life could one expect, ceteris parabus, between a vee bearing liner motion sytem, CNCRP milled steel with skate assembly, and linear rail w/bearing (Hiwin?).
Thanks all! Btw I hope I posted this in the right place.
