586,361 active members*
3,560 visitors online*
Results 1 to 10 of 10
    Aug 2011
    617
    RDCam/Laserwork V8 - Want User Manual ?
    Hi all
    I'm new to Laser (built and using CNC router for years)
    I've just bought the chineese 50w 30cmx50cm laser machine.
    It came with RDCAM V8
    but the manual on disk is V6, the printed one is V3 !
    I'm after a copy of the manual for V8, to match the software.
    If not .. 1st question, vector cutting
    Double click layer
    set speed and power
    set "cut"
    At the bottom is a box to select cut through...
    All the above is in the manual
    But .. under that check box is another "through cut power" which defaults to 50%
    This isn't mentioned in the old manuals, so I'd like to know the effect this variable has on the output cut.
    Thanks in advance
    Rich
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Aug 2011
    617
    Re: RDCam/Laserwork V8 - Want User Manual ?
    I'll do a screen shot when I get a sec
    Aug 2011
    617
    Nov 2013
    Is there any way to import a vector file at the original size it was created?
    When I import as a .dxf into RDcam v6 shrinks the vector file to a very small size. I would like to be able to adjust to engraving an image then cutting the outline within the same file. Is that possible?
    Shenhui 4'x4' 130w & 80w dual head laser.
    Chicago
    Jan 2008
    940
    Is the DXF in inches or MM when I import MM it is the correct size so I always export my drawings as MM
    Quote Originally Posted by TrickyCNC View Post
    Hi all
    Double click layer
    set speed and power
    set "cut"
    Thanks in advance
    Rich
    Hi Rich
    here's the controller manual we OEM with RD:
    RDC6442G And RDWork Software
    hope it can help you,
    good luck
    www.thunderlaser.com
    Jun 2012
    Red face Re: RDCam/Laserwork V8 - Want User Manual ?
    How!? Are your running RDCAM on Ubuntu? Did you use the Stefan Schuermans method?
    I'm trying to use Inkscape with RDPlug (the Corel/AI/Cadian/AutoCAD plugin). I've done some research on my GitHub repository here (https://github.com/crushedice2000/RDCAM). However I'm not a expert in reverse engineering. I want to rewrite RDCAM as a GPL project. (without copying RD code, but only rewriting from scratch).
    You may be interested in reading this file (https://raw.githubusercontent.com/cr...g/RLaserV5.bas)
    Aug 2011
    617
    Hi
    I don't know what "Stefan Schuermans method" is ?
    I use EMC2 for my CNC machine .. I just set up RDcam and it worked
    other competers it dioesn't seem to ? .. but I have dual boot with winXP , so all is good :-)
    Jun 2014
    611
    Hi Rich,
    1. I need to explain what is "through power" firstly. for example, you need to cut 3mm acrylic, but laser can't through the acrylic at the beginning position, (other position is no problem) so you need to increase the starting power, right? so you need to set " through power" and "open delay" this time.
    Please tick "laser through mode", then set "through power"(50~90 should be fine), and "open delay"(it means the time stay at the start point).
    2. you can download the manual from our website.
    3. RDWorks support mm or inch now.
    hope it is helpful to you.(nuts)
    Jun 2014
    611
Name:	set power through.jpg
ID:	298198 forget the picture, sorry.
  1. MULTICAM CNC user manual
    By jimmyCNC in forum Multicam Machines
    Last Post: 01-02-2018, 07:22 PM
  2. User Manual
    By rstbkt in forum BobCad-Cam
    Last Post: 11-07-2013, 11:32 AM
  3. Nk105 G2 User manual
    By AmicX in forum Machinery Manuals / Brochures
    Last Post: 08-10-2012, 11:18 AM
  4. User manual for LC30 OSP3000
    By Fredlev in forum Okuma
    Last Post: 09-02-2009, 07:56 PM
  5. MaxNC 8 user manual
    By andywong1026 in forum Benchtop Machines
    Last Post: 08-21-2009, 02:39 AM
