586,377 active members*
2,643 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Sl3h clunking during speed change when running G96
Results 1 to 3 of 3
    Apr 2010
    38
    Does any one else experience a clunking, possibly transmission clunk when running g96? It happens when changing speeds after slowing down for a larger diameter and then spinning up again right before heading back into a smaller diameter. Occurs even with small moves in the x when changing rpm.
    Another shop has sl3 lathes also and they make the same distinct noise. My shop is smaller and perhaps that is why it is more noticeable. I have pulled the transmission out and cannot find anything that stands out, loose keys etc. Is it simply the case of a older transmission?
    Any thoughts on this would be great.
    Mark
    Feb 2009
    6028
    Re: Mori Sl3h clunking during speed change when running G96
    Keyway on one of the clutch packs probably.
    Jun 2012
    2
    My Sl-400 does the same thing. It is more noticeable when in manual mode. It is because the gearbox.
  1. Replies: 0
    Last Post: 12-13-2013, 07:13 PM
  2. Trying to get Mori SL1A up and running.
    By crittenden in forum Mori Seiki lathes
    Last Post: 08-11-2013, 06:01 AM
  3. Running hours, easy to change?
    By motordude in forum Fanuc
    Last Post: 03-29-2013, 03:17 AM
  4. Mori running on 240v RPC - voltage sensitive?
    By damae in forum Mori Seiki lathes
    Last Post: 11-20-2009, 07:03 PM
  5. mori seiki SL3H
    By cnvenes in forum Mori Seiki lathes
    Last Post: 02-12-2009, 08:58 PM
