Re: Boss Project & Questions
Originally Posted by
sdmuleman
how much effect does a digital stepper control have vs the older chopping type?
They are both chopper drives. The difference is likely the 'front' end rather than the power section. I would use the older (less expensive) drivers, I doubt you'll ever notice the difference. I am using Compumotor drivers myself. They were made in the early '90s. Also, the stock stepper motors are not well suited to microstepping (since microstepping didn't exist when they were made). Yes you can drive them with a microstepping driver (as I am also), but the microsteps are very non-linear and don't effectively produce much better than half steps (which is why I'm upgrading). They work just fine but effective microstepping should provide better surface finish while contouring.
The biggest reason to use KL- drives vs. Gecko is they run off line voltage (I believe) so you don't need to mess with the transformers like you would with Geckos. Plus the higher voltage will get you better performance. This is my biggest reason I'm using Compumotors.
I would think you could find a way to get everything into the single enclosure. When my machine is ultimately completed, the rear enclosure will be replaced with one that is 1/4 the volume of the original.
sdmuleman
Do you have a rough idea of when you plan of swapping your motors? I've seen them on ebay, but I'd rather not mess with ebay and support a forum member if I can.
Sorry, I really don't. Anyway, you'd have to fight with 1875 since he has also expressed interest in them. I do appreciate your not wanting to go to eBay.
I'll send a PM re. manuals
sdmuleman
Is there a way to remove the table without taking the ball screw apart?
The screw itself on the X axis does not rotate - the ball nut does. TarHealTom has a thread that shows him removing the table of his BOSS5. I believe it is just a matter of removing a few bolts.
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
