We're machining plastic. The problem we're getting is that the cut plastic gets wrapped up tightly around the rod and makes a mess of things. We tried upping the RPM which helps but then just melts the plastic.
Is there a better way around this?
Cooling it ?
Gesendet von meinem SM-N9005 mit Tapatalk
