HI ALL NEED HELP ON CONFIG 5 AXIS HEAD/ HEAD B AND C
DO I HAVE TO WRITE A SCRIPT FOR THE B/C
DISTANCE CENTER FOR TILT AND ROTATION .
OR INPUT SOMEWHERE IN MACH 3 THANX
Your g-code needs to account for this.DO I HAVE TO WRITE A SCRIPT FOR THE B/C
im new at this, do i have to input any parameter for tilt and rotate compensated offset
when the head cut tilt drill on the angle and cut simultaneous.
so everything do in the cam and post compensate that
Mach3 can NOT compensate for 5 axis offsets. The g-code needs to tell it exactly where it needs to go. So it's up to your CAM and or post processor.
Or LinuxCNC could save you, using 5 axis kinematics module for compensation by controller in "real time"...
