I need to ask about some issues I met during my last job on my homemade CNC router.
1. I was engraving the 1st attached file (Quick Engrave Letters-Roses.zip) and suddenly it stopped 1-2 minues before the end of the process and mach3 showed the 'Limit Switch Triggered' message without the machine really hitting any limit switch. I pressed 'Reset' button and it continue the engrave process for a while and then again it stopped and showed the same message. I then checked the cables, I checked the motors and I could hardly touched them continuously for 3 secs, and then I pressed 'Reset'. I resume again the process and it managed to get it done.
2. While I was cutting the 2nd file attachment (Profile Borders Roses-Letters End Mill 3mm.txt), when there was a 90 degree turn, the spindle couldn't cut square but cut it with radius. I had motion mode set to 'Constant Velocity' and while my spindle kept going I changed the setting to 'Exact Shop'-> Pressed 'OK' on the fly and then I noticed that the spindle followed a diferrent toolpath than the mach3's toolpath. It was something like failing to resume from where it had stopped. I am not sure if it was my bad but I needed to mention this. I changed the setting on the fly. When entered the General Config menu in Mach3, it stopped the cutting process and it resumed when I hitted 'OK'.
3. Finally, when I was cutting the 3rd attachment (Heart Border-Butterfly Hole Border Profiles.zip), I needed to Feed Hold the process in order to clean the cut area from already cut parts and dust. When I resumed by pressing 'Cycle Start' the motors ran much more slower without changing the feedrate on mach3 screen. I then stopped the process, I loaded the file again and the slow-mode was gone.
