Looking for a quote on a simple drill sleeve. This is used in commercial construction to center a fastener hole through a pre-drilled hole in the material being attached on site. Tolerances can be fairly loose with the exception of OD. This must pass through "Q" size drilled hole. Please quote 100 pieces.
Doug
