Hi newbie question just started using onecnc xr3 mill
I would like to know if when selecting leave for finish and a figure of say 0.5mm
in the pocketing in stock tool paths if I then click next and click none for finish depth or bottom only will it leave the pocket shy or will it cut it to size reason being is I have pocketed ramping in with a tipped cutter to rough out then done a profile chain with a 16mm end mill to finish the boundaries or will I need to offset a boundary say 1mm in select this for my rough then select the profile chain and the larger boundary to finish
Would also like to know if this goes the same for the circle tool as I need to leave some of the larger holes shy and then remove the item and place in the jig borer so I can be sure to get the bearing sizes exact as our cnc is slightly worn and I only have one chance with this item
Many thanks lee
