586,116 active members*
3,251 visitors online*
    Oct 2013
    153
    Solidcam 2014 sp1
    Hi anyone tried the new version of solidcam sp1 ?
    Oct 2007
    499
    Re: Solidcam 2014 sp1
    I have downloaded it but I haven't installed it yet. Given the problems they had with SC2013, I will wait until my reseller says it is safe.
    Oct 2013
    153
    I found a bug on thread milling . When using the top to bottom option the tool travels from the bottom to next position skipping it's retract to the clearance plane .
    Oct 2013
    64
    Ouch, that can be expansive.
    Sent from my A1-810 using Tapatalk
    Oct 2013
    84
    I'm a newbie using SOLIDCAM 2014 SP1 here. I tried thread milling using a thread mill from onlinecarbide 3/8-16UNC and i didn't encounter any clearance issue to the next hole, I ran my machine without tools on the first run just to be sure. I don't think i have my feed/speed correctly though... making lots of noise... squeeching!!! Threads looks great though. This test aluminum plate should only have 2 holes, I shifted the hole on the 2nd run trying to eliminate the squeeching high pitch sound.
    Regarding the clearance issue that imachining-6061 reported.. I encounter this when I upgraded to Solidcam 2014, it was using the safety distance instead of the clearance level, it was the post processor for me. SolidcamX took care of my problem since I purchase his post processor service, I'm just waiting for him to fix the transform-translate- matrix gcode issue that I'm having now.
    https://lh5.googleusercontent.com/-v...609_182100.jpg
    i have solidcam demo version, can i load gcode with this?
  1. Featurecam 2014
    By Tutan in forum FeatureCAM CAD/CAM
    Last Post: 02-04-2014, 04:47 PM
  2. SURFCAM 2014 R1
    By forjaco in forum Surfcam
    Last Post: 12-11-2013, 09:49 AM
  3. Vm 2014
    By CTAC in forum Visual Mill
    Last Post: 09-25-2013, 01:49 AM
